Real world Kimbo owner reviews
Skinhyfish
Looking for a ski chalet for next season. I have had many truck campers. Curious if people are happy with kimbo for the simplicity. Love to hear pros and cons. Being lighter feel much wind drag or heavy in rear compared to others?
thanks Zach
Mickey Bitsko
According to their website, under 1200 lbs fully optioned,
22k-40k usd$ with no commode... says they fit nicely on a mid-sized truck, like Toyota Tacoma..lol
calameda
We had a 2020 model for about 18 months. Simplicity and relatively low weight are great, and DIY upgrades are easy. We got excellent mileage on an older RAM 2500, so long as you minimize gap between cab roof and camper cabover, aerodynamics are good. Bed very comfy. Arctic tern windows are great.
They do (or did) cut some corners. All comments below pertain to a 2020 model.
Don’t bother with the 3 way propane fridge, its loud at night, fussy, and requires venting which lets in cold air. Go with more efficient DC compressor model.
We found 100 watts solar inadequate, especially with a DC fridge. We added a panel, could have added another.
Goal Zero 300 system was meh, we added two 33 Ah batteries for 100 Ah total. That worked for us and our laptops and gadgets.
Fresh water capacity way too limited. One might install wheel well tanks outside, then plumb them in, but obviously not optimal in the cold. We just lugged around jerry cans, not optimal.
We never missed having a gray water tank. Or a dedicated toilet or shower. But might feel differently with a lot of winter camping though we did camp in snow several times with no big complaints. YMMV.
Liked the Dickinson furnace, reasonably efficient, but it can be fussy to keep lit (clean burner regularly) and given its height, the lower cabin can be at least 10-15 degrees colder than upper.
Not a fan(!) of the Fantastic Fan, too loud, settings too coarse. Much prefer Maxxair.
because we stored stuff in the space between bed sides and camper, those wheel well sections took a beating. I would coat them w raptor or linex or other bedliner coating. Might want to do that under cabover and front wall too. Or even whole thing, depending on how much you like the highly reflective aluminum. It will scratch.
probably other stuff I’m forgetting.
sn_85
Good to hear some real world feedback. I considered them for a bit but they're just a hair too small. It's at least encouraging that your complaints about them is more about component selection rather than actual construction and QC. I feel like the fridge, solar panel, goal zero, water capacity are all things you can correct down the road or maybe even omit on the initial order. It's the structural things that can't be fixed.
Here's the largest thread I've seen on Kimbo campers and user experiences. A lot of user mods as well.
calameda
ADDENDUM: can’t believe i forgot this, but thermal transfer is one of the biggest issues w the Kimbo in hot or cold conditions. The stainless retaining screws that hold the insulating panels in place readily conduct exterior heat or cold into the camper interior, and are centers of condensation in winter.
But worse are the two long vertical aluminum partitions (fins) on either side. These are attached (riveted) to exterior skin, and project perpendicular to the walls; they are thus perfectly designed to conduct heat and cold from the skin to the interior :(
Kimbo really needs to redesign the attachment of the fins. And consider changing to a non conductive fastener for the insulating panels.
dhuss
