Sizing an off-grid Air Conditioning (AC) and fan system
ReluctantTraveler
Are you building your own box? If so, have you thought of simply building your own ducts, perhaps with booster fans?
You might dump the cold air into a plenum and then use something like a bilge fan (with a speed control to reduce noise) to force air into your two sleeping areas. Ideally, you want a big fan with low volume for low noise. There are some ideas here: https://www.amazon.com/s?k=6+inch+bilge+fan+12v&crid=26MV1OE8UKCMC&sprefix=6+inch+bilge+fan+12v,aps,517&ref=nb_sb_noss
I am, and I'd be happy to run my own ducts if I could find an energy-efficient system that supports ducted installations. So far, I have not.
1000arms
Have you read through IdaSHO's thread?
Have you looked at this post in another of IdaSHO's threads?
ReluctantTraveler
I have. He chose to use a residential in window air conditioner. That comes with its own set of tradeoffs and design challenge is that I don’t think are appropriate for my particular needs or wants at this time.
DiploStrat
My comments are in the thread. You will note that I recommended a radiator fan with a PWM speed control to assure adequate air flow to the compressor.
Seems that is what he had to do eventually.
Peter_n_Margaret
This is on our existing MH as part of about 1.2kW of solar. The new build will have about 2.1kW of solar.
Check the efficiency (COP = Coefficient of Performance) of A/C contenders carefully. Everything efficient will have an inverter powered compressor motor that reduces power consumption dramatically as the compressor slows down. I have not seen any such 12V units.
Cheers,
Peter
OKA196 motorhome
1000arms
Good, I'm glad you are aware of the thread. If you haven't already considered a through-the-wall AC, you might want to. It would likely eliminate some of the problems IdaSHO had, although it still might not be what you want. :)
ReluctantTraveler
Cheers,
Peter
OKA196 motorhome
thanks for the vid!
looks like the 12v unit I’m leaning heavily towards does have a condensor, unless I’m reading this wrong.
Peter_n_Margaret
Every a/c ever built has a condenser (and an evaporator). The major efficiency increase of the latest ac models is the use of inverter motors which are able to maintain high efficiencies at low motor speeds (where they spend most of their time) as well as high speeds.
Cheers,
Peter
OKA196 motorhome
ReluctantTraveler
Cheers,
Peter
OKA196 motorhome
Doh, you DID say an inverter motor. Sorry about that!
Looks like the Mabru does also include an inverter. Van Life Outfitters did some tests on both electrical draw and db levels in operation, independent of what the manufacturer states in their literature.
