**SOLD**AT Overland Summit 6.75
rbrownmr2
*Delete this posting if desired. Thanks Expo members for your interest, and inspiration!*
At Overland Summit camper off of a Ram 6.75' bed for sale. Camper is in excellent condition and has been stored inside when not in use (truck and camper are stored inside). I built an interior seating/lower sleeping area out of 80/20 that is padded and carpeted, and secured to the bed with turnbuckles for easy removal if the entire bed space is needed for hauling. There is a ton of storage under the platforms for gear/bins/water cans/etc. The lids on each bench lift to access inside if needed. We have never ran out of room and love not having to unload the truck to go to bed or use the benches. I welded an aluminum tailgate cover to replace the AT foam tailgate seal that was not ideal for the shape of the Ram tailgate, no more water intrusion! We ran an Espar S2D2 diesel heater in the bed of the truck that would keep the interior 70F+ even in below freezing weather with the help of the insulated thermal liner, which also acts like a sort of blackout curtain, blocking out all light and allowing us to sleep in on occasion. Let me know if you have any questions. Camper will be removed from the truck in the next couple of weeks and stored near Bellingham, Washington. Asking $12,500
Rough build sheet today:
Summit: 6.75’ - $13,400
Tern Overland Euro Window with bug screen and privacy screen: $1,100
Tern Overland Hatch Door: $875
MaxxAir 6200K Fan: $449
Roof Mounted Aircraft Track Only: $395
Fiamma F45S 8’ awning $1100
Thermal Liner: $1,200
200W solar Renogy $225
Dimmable strip LED white/amber $100
wall steps/handles $40
welded aluminum tailgate cover to prevent water intrusion $n/a
80/20 interior padded & carpeted seating/bedding area front of bed and along passenger side $600
Lagun table w/ checkerboard top $200
Noco 120VAC pass through $n/a
rbrownmr2
Will this fit on a Ford F250/F350 6.75' bed?
See the "Will it fit my truck?" section found here:
It appears the camper would fit, but always a safe bet to check with Mario and his team for vehicle specific fitment questions, as they are far more knowledgeable in that department than I.
iStan814
