Wm Hill
Thanks for the kind words about my build- much appreciated!Such great work! Loving the aesthetic of your trailer.
Can I ask a noob question and what/how does the bearing buddy help ? Keeps the grease more contained longer?
The bearing buddies replace the dust cab on the hub. There is a grease fitting on a sliding plate with a spring. You pump the hub with grease until the plate starts to move. The spring keeps some pressure on the grease to keep it in the bearings and races. It also helps push out moisture. The advantage is you don't have to pull your hubs off yearly to re-pack the bearings in grease. I have lost a couple of wheels through the years from a lack of grease, and that usually ends up pretty badly. You don't want to fill it completely, it will push grease past the seal and make a mess and may ruin the seal.
