2015 Jeep Wrangler JKU Rubicon Hardrock; Ursa Minor J30 Camper Top, GooseGear, 37s, etc--SOLD!
mk216v
Der Chef der Fahrzeuge
(2 older pics back when it had 35s on it, to show the full setup deployed. Chairs/table not included)
• 2015 Jeep Wrangler Unlimited (JKU) Rubicon Hardrock, 6spd manual, Baja Yellow over black leather
Original Build Sheet << (CTL + Click to View)
• Mileage 71,598
• Serviced 70,663
I'm the 4th caretaker of this professionally built and well-maintained JKU Rubi. All previous owners were/are active on ExPo (Jason/RubeGoldberg, Jim/JRLTX, Dan&Jenny/OldGreyShoe); they get all the credit for the high quality of this extremely complete and capable adventure rig.
Detailed information...
EXTERIOR
Ursa Minor Camper
Ursa Minor Standard Jeep J30 PopUp Camper Top (JK)
Shell Body Color Selection: Standard Black Texture
Roof Top Color Selection: Roof Top - Silver
Rear Quarter - Drivers Side Selection: Solid Quarter Panel
Rear Quarter - Passenger Side Selection: Solid Quarter Panel
Power Outlets – 12V in header: Power Package
Navigator Headliner Organizer: Navigator Headliner Organizer
Rear Load Bay LED Lighting: 2 LED Reading Lamps in Top
Rear Wiper and Defrost: Standard Glass - no Rear Wiper / Defrost
Installation: J30 Factory Install
Note; add'l mattress foam added--very comfortable
UrsaMinor Awning mounting brackets (passenger side)
RhinoRack 270° Batwing Awning
RhinoRack Awning Side Panels
AT Overland JK Propane Mount kit w/ Propane Tank
Mopar Winch Mounting Kit for 10A / X / Hardrock Bumpers
Custom Fairlead Mounting Plate
Warn Winch 9.5cti-s
Factor55 Fairlead
Factor55 FlatLink
Factor55 HitchLink 2.0
Drake (DV8) RocKlaw hood latches
Mopar Hood Lock
Waterport Tank on Front Bullbar; w/ Hose/Sprayer (easily removable)
AEV Rear Tire Carrier
AEV Fuel Caddy
NBX Trail Gear spare tire "trasharoo"
Bolt 5/8” Receiver Hitch Lock
LIGHTING
JW Speaker J2 LED Headlights
JW Speaker 279J LED Taillights
Poison Spyder A-Pillar Bracket
Baja Designs Squadron Pro Pair w/ covers
Baja Designs Rock Lights
Baja Designs Scene Lights (more rock lights)
Rigid SR-Series Pro Midnight 20” Spot/Flood combo light bar
Rigid 20" Light bar mount
Rigid SR-Q Series Pro Diffused Backup surface mount pair
Brawlee LED Rear Glass Lift Gate Dome Light Bar
SUSPENSION, STEERING, DRIVETRAIN, WHEELS/TIRES, ARMOR, EXHAUST
Fox Performance Elite Series 2.5" Remote Reservoir & DSC Adjustable Shocks; ~6000mi ago
Fox Factory Race Series 2.0 ATS Steering Stabilizer
MetalCloak susp lift and adjustable front/rear control arms
SteerSmarts YETI XD tie rod
SteerSmarts YETI XD “no drill” top mount drag link
SteerSmarts YETI XD JK Track Bar Relocation Bracket
Artec Lower Front Control Arm Skids
Synergy C-gussets
Yukon 5.13 gears
Adams Extreme Duty 1310 Front CV Driveshaft
AEV Pintler Wheels in gunmetal gray
Mickey Thompson BajaBoss A/T 37x12.50R17, w/ new TPMS sensors, and aligned; ~2500mi ago
AEV ProCal
RockHard Rock Slider/Step Rails (Patriot Edition?)
MetalCloak UnderCloak skid system
Rokman Front & Rear Diff Covers
MagnaFlow 15219 Y-Pipe and Loop Delete Kit
INTERIOR
Goose Gear Cargo Plate
Goose Gear 60% Seat Delete
Goose Gear 60% Seat Delete Bracket
Goose Gear 40% Seat Delete
Goose Gear Cubbies
Goose Gear Camp Kitchen 2.3
Goose Gear Passenger Rear 2Drawer Cabinet
Goose Gear Large Utensils Box
ARB 50qt Fridge/Freezer
Coleman 2Burner Stove
4' Propane Hose w/ Adapter for Propane Tank to Stove
Outback Adventure Products Trailgater
Passenger Front Seat Headrest Safe
GraBars USA Front and Rear GraBars
AMEREX Fire Extinguisher w/ mount
XG Cargo Stealth Gama Roll Bar storage bags
MOEBULB Roll Bar Storage Bag
Weathertech Privacy/Sunscreen Shade Kit for 5 Windows
Note; The Goose Gear CampKitchen has a double slide operation, allowing the fridge slide and/or the stove slide to be an independent or combined operation. Tailgate table drops down and provides table space and a slide-out Bamboo cutting board. Bottle jack/tire iron is stored in the rear, under an access plate. Recovery gear, onboard air equipment, awning sides/stakes, hoses, etc, are stowed below the Goose Gear rear seat delete. Lots of extra storage room.
COMMAND CENTER
Vector Off-Road JKE-Dock
Ram Mount 1” ball
ELECTRONICS
Interstate Battery
sPOD BantamX
sPOD 8 switch control panel above rear-view mirror
RFI Antenna Cell Booster
GoalZero Yeti 1400 Lithium Ion PowerStation
GoalZero Yeti Link Car Charging Kit
Note; The Goal Zero Yeti 1400 is mounted in front of the Goose-Gear CampKitchen station, to 80/20 T-slot extruded aluminum via 1" nylon ratchet straps. The upgraded Goal Zero Yeti Link Car Charging Kit with 80A fuse protection has been professionally incorporated to the Jeep electrical system. The Yeti 1400 is charged up to 700 Watts/hr when the engine is running. When the engine is not running, the Yeti is not charged by the vehicle system. The Yeti 1400 provides 1500W/3000W Surge, pure Sine Wave 120Volt AC power, 12 Volt DC power, has 2 USB and 2 USB C connections. Input power: AC with fast charger, DC from Jeep electrical system, and solar power.
ACCESSORIES
ARB Twin Compressor w/ Hose
MetalCloak ARB Compressor Underhood Mount
Powertank Air Gauge
Jeep Trail Rated Recovery Kit
Snatch Block
Two Soft Shackles
8’ Tree Strap
AEV Spare Tire Jack Base Booster
Stahlbus Oil Drain Valve/Hose System
The Ursa Minor PopUp Camper Top is easy to use, and provides a very comfortable and secure setup. Being able to enter/exit the poptop through the 2nd row flat-floor area, allows a lot of flexibility. You can stand up inside, get dressed, etc. You can also securely access the driver seat without ever having to leave the vehicle interior.
Coupled with the Rhino Rack Batwing Awning and Goose Gear Camp Kitchen, it all makes for an enjoyable place wherever you are, to set up camp and relax after a day of expedition travels.
It's been used, but not abused. Exterior paint has been well maintained, as has the interior. Some trail scuffs on rear bumper, tree branch scuffs on Ursa Minor camper shell sides, few paint nicks, 1 small ding above rear bumper. Overall condition is very good.
The cost to build this 2015 Jeep Rubicon, without labor charges, is over $85,000.
• Clean and clear title in hand
• Located near Bend, OR
• $45,700
Will entertain trades.
No time wasters please.
More pics attached.
mk216v
More pics.
mk216v
More pics.
mhiscox
Exp. Leader Emeritus
That is a very fine writeup and picture show of a nicely-built Wrangler Overlander. (I think we all wish the average ExPo "For Sale" post would try to be about half as useful.)
Good luck with the sale. There aren't very many options with this much off-road capability that are as well set up for the comfy camping part.
mk216v
Thank you for the kind words Mike. I always try to be as detailed as I can.
Appreciate it, and couldn't agree more. It's a win-win!
STHS
Got to love For Sale Ads with lots of good clear pics and very comprehensive and detailed write-ups! 👍🏻🍻🇺🇸
Jakegazan
Interested in an 6.2 Ls swapped Jeep jk with 8k miles
with a 6.2LS engine and 6 speed transmission done in-house by turnkey in Southern California. Axles are Currie rock jock 60s., ARB locked front and rear. King coil over suspension including bump stops from EVO manufacturing. Atlas speed transfer case, rock ram steering. 5 37 geolander tires with less than 500 miles but could easily run 40s.
5 walker evan bead locks, full poison spider body
armor and fenders, interior seating has twisted stitch seats with lumbar support and heated seats. custom roll cage. Aftermarket sound system and procomp rock lights
My add is up on the first page right now. I’d be interested in a trade + cash if your interested.
mk216v
Thanks for the offer, but I'm looking to fill some of my coffers back up vs spend more $ on another vehicle (which I don't need).
GLWS, looks like a well built JK you have.
Don_TLR
Damn nice jeep and should go fast with this well documented for sale ad. I like the headrest safe, never seen one of those before.
PNWav
