Keeping equipment alive in the garage
mad85
I have a Land Rover Discovery with a dual battery setup running a fridge. As I use the fridge almost every weekend, I prefer to keep it on and keep some essentials (beer) in it rather than having to fill it up every week. My problem is that in the garage the solar panels on the roof will not charge the battery and while the deep cycle gel battery can probably keep up for a couple of days, i prefer if there is a way of switching it to A/C (plug it in). I have tried using a trickle charger but that one is not designed to keep a battery charger while it is used. Which would be the best and easiest way of keeping the fridge on and the battery healthy?
VanWaLife
This might work for you. I use a 2amp version so I can leave all my USB devices in the car charging without draining the battery.
mad85
the fridge pulls around 5amp at 12v so the 10A charger should be man enough but im not sure how these intelligent chargers would work. my current charger gets confused when the fridge kicks in and decides its a bad battery and simply stops working. I was thinking instead using a charger which can work as a supply. not sure if that would damage the battery long term though
Ozarker
I think I'd pigtail power input to fridge, disconnect it from vehicle when inside, 110 v through inverter 12v and connect it.
Ozarker
Surge may damage a smart charger, I use a 15 amp inverter, 110v ac to 12v dc.
mad85
yes i have the fridge factory transformer which i could plug into the main, but it is a bit of a hassle to unplug it every time i want to leave it for a few days. This car is my 'daily' (although i dont drive everyday, as i work from home)
Ozarker
The up side to that hassle is that it only takes seconds every few days, :))
chet6.7
Is your current charger a dumb charger? My CTEK smart charger has a supply mode but I have not tried it.
My small fridge is behind the seat, the area where the frige is mounted is tight. I can switch the cords for the fridge from AC to DC, but I would prefer to find a workaround as well.
AbleGuy
Officious Intermeddler
X2
This is the one we’ve used the past coupla years:
I saw a van recently where the owner had permanently installed this under the hood. You just had to pop the hood and grab the plug to use it daily.
mad85
Its an alpicool 35l fridge. Doesn't have dual input unfortunately. Its fitted inside a drawer system so i need to take it off the car to put it on AC. I think the ctek on supply mode would probably work
mep1811
Gentleman Adventurer
If I'm using the fridge at home I just plug into the A/C with an extension cord. Since your fridge is not dual voltage you could use one of these. I use one of these to run my 14 qt Engle in the garage.
Toyaddict
I have a 6 amp marine on board charger in my van. Works great for my needs. Solar controller throws code for over voltage if I use the charger while also making solar.
Linesman1776
