1999 Ford F450 Super Singled 7.3L diesel 48k miles (poor mans earth roamer?)
jaho
well, after much discussion we have decided to add the camper to the package and see if anyone is interested in an expedition ready vehicle for $85k (truck plus camper, truck info in first post), significantly cheaper than a built out sprinter, and depending on your needs roomier and more capable.
Some information about the camper: (see images for camper specs from factory)
-1998 Bigfoot 30C10.11 - This is a great layout. The bathroom and closet create a lot of separation between the large bed/bedroom (overcab) and the dinette/kitchen
- See images for camper specs, but most important is full dry bath (separate shower), 38 gallon freshwater, power jacks
- We have added 300 watts of solar panel to the roof (2x 150 watt panels)
- 300 amp hours of lithium ion batterys
- 3000 watt Victron hybrid inverter
- Victron solar charge controller
- Victron DC-DC charger
- All Victron components bluetooth enabled to connect to the app
- Addition plug installed for added mobile solar panels to increase solar capacity
- Guzzle H2O water filter with LED UVC and seperate water faucet for drinking water
- 2x 20 lb propane tanks
- New memory foam mattress
- Camper interior fully repainted in 2023
- USB A and C outlets installed at dinette for easy charging of devices
- Locks on all drawers to keep them closed while driving
We have a baby and have found this camper to be amazing for a family of 3 or 4. The only issues with the camper currently are that the hot water heater has a fitting leak so it is currently bypassed. If we keep the camper I will either rebuild existing unit or replace with 12v only hot water tank.
jaho
How difficult is it to remove/install the camper?
Quite easy. The jacks are electric, controlled with a wire remote control (camper is from 1998). I never love truck campers on their legs, just always seems a little sketch, but I've taken the camper on and off probably 15 times since I've had it.
PNWav
