2004 E350 6.0 Box Van Camper Price Drop
2004.5 Ford E350 Box Truck Camper Van 1 Ton cutaway chassis 16K towing capacity
Bulletproofed 6.0 Powerstroke
Chassis and Drivetrain
2004.5 E350 Cutaway Chassis 6.0 Powerstroke with Automatic transmission. Fits in a parking spot!
33" Toyo AT3 tires
Custom Front bumper with Warn M12000
Sony Headunit with subwoofer and back up camera
6.0 Engine is 2004.5 Bulletproofed by the previous owner (have documentation) at 154K miles with ARP Head Studs and new heads and head gaskets, new injectors, oil cooler, updated FICM, 2005 high output oil pressure pump, the FCP and ICP replaced, new glow plugs, cold air intake, Sinister Diesel coolant filter, 5" cat-back exhaust, blue spring installed into engine-side fuel filter housing, complete new engine harness from Ford, and new glow plug harnesses. It also has a mild no-smoke power tune to bring it to around 350 horsepower through a SCT Tuner. I have also used the SCT tuner to firm up the shifts in the Trans. Still has a factory catalectic converter and an upgraded EGR cooler. I was told it passes emissions in Salt Lake City which has the same requirements as California. At around 175K miles the previous owner installed a new Ford factory electric fuel pump. A new turbo with a high performance compressor wheel, and an aftermarket radiator, new main serpentine belt, and belt tensioner were also installed around this time.
The previous owner changed the oil every 3,000 miles with Chevron Delo which is what I have continued to do as well. I have also changed the fuel filters as well as the external transmission filter and coolant filter every 6 months. I have fixed several small issues with the charging circuit since getting the van and have needed to do little else besides fluid changes. It has been my most reliable vehicle I have owned, included are several boxes of spare parts as well.
Box
6.6'W x 6.5'H x 10'L Box
Box has Two large windows and 1 small as well as a side door with fold out ladder
Rear swing out storage rack with ladder for roof access
Roof Rack
Fantastic Fan
Coleman 110v AC unit
Full size bed with 8inch mattress
Cedar tongue and groove ceiling with recessed puck lights on a dimmer switch
All interior walls floor and ceiling were insulated
Roller door is currently bolted shut and walled off for better sound and insulation properties I was eventually going to install a toy hauler door to use as a fold down porch and a lift system for the bed. Currently the bed is bolted in place with an under bed garage of sorts.
300ah of deepcycle house battery connected to the alternator charging circuit. No solar installed yet but I have yet to need it with this battery setup and the minimal load with just lights, fan and the diesel heater.
Vevor Chinese diesel heater 8kW this is not connected to the vehicles fuel tank, It currently has its own separate tank installed on back of van.
Wood laminate flooring throughout box have extra to include as well
Located in Big Sky MT outside of Bozeman asking PRICE DROP ***18k OBO***
Originally planned to install a 4x4 conversion and either build out this current box with cabinets and an improved rear door or build a composite box to install on the chassis at the time of a 4x4 conversion. Time has become an issue and I am looking to get something more complete so I can spend my time using the vehicle instead of building it out.
Will updated with more pictures as well as interior pictures in the near future
Some interior photos showing basic camping layout
nyyankees588
Pretty sweet rig - full transparency, I'm (unfortunately) not in the market at the moment. Any photos of the rear swing out/ladder setup? Is the interior of the box really 6.5' standing height? If so, that's a rarity... The vast majority of the e-series box vans are just under 6' of standing height.
Cheers!
Sent from my Pixel 3 using Tapatalk
Frijotelo
Bump for a cool rig. Question: the box dimensions you provided are for the interior? i.e. the interior height is 6'6"...?
Cheers!
I'll measure the interior height that may be the exterior height of the box
Here is some photos from the previous owner of the swingout setup. The whole metal cage on the back swing out to the passanger side.
