Boreas Campers in Pueblo, CO now selling composite panels and off-road chassis with Cruisemaster for DIY folks!
Boreas Campers
Approved Vendor
Just wanted to let you guys know that we sell the composite panels that we use to manufacturer our campers.
The panels are $17 per square foot for raw panels and $22 for CNC cut panels, if you provide a blueprint.
We also sell our off road chassis with Cruisemaster suspension.
Reach out to me at adam@boreascampers.com with any questions!
Check out out website at boreascampers.com
Boreas Campers
Approved Vendor
Also wanted to make sure people knew that we sell our rolling chassis as well. We do not do custom chassis, we only sell the ones we put our campers on.
Here is the link to the two chassis that we sell:
Adam@boreascampers.com with any questions!
rruff
The exterior composite is woven FRP and the foam is XPS. 1.8 inches thick and has an R7 insulation value.
(y) Woven FRP is good! Glad to see you getting into this game!
Do you mind sharing the specs on the FRP and foam? The core foam doesn't look like any XPS I've seen.
Also, for anyone who thinks $22/sq ft is expensive, even a 7x7x10' box is only 378 sq ft, or $8,316. Seems pretty reasonable for panels cut to size and ready to go.
Boreas Campers
Approved Vendor
Hey Ruff, the XPS is 2.37lb per cubic foot. It is a different color as it is not "branded."
The FRP is woven 2mm.
Thanks for the kind words!
rruff
That's heavy foam compared to the typical pink or blue that's available. Are skins gelcoated?
6912
is that skin Fiberglass/Filon? if just woven 2mm. how did you stop print through if just /Filon that just mat and a lot of resin . We have been making our panels for over 15 years and have always used mat next to gel and then woven . by using these panels no faster are easier way to build.
Using woven makes all the difference in the world. .What you save in tools building. To me will pay for the panels. To me, the build goes so fast and easy . No rot to worry about. Makes the trailer cooler and warmer. and any repair can be done at home. if any take a long time to build no warping . Can not say enough good things about building with composite panels they have here
ITTOG
I wish these were available in 2020 before I started building my camper. Who knows, maybe this speeds up version 2?
DanoWall
