Ram 1500 build ... should I even bother?
ThundahBeagle
Figure about 100+ pounds for tubing and the plates that sit on the bed rails.
Before doing that, I’d look at a gutter clamp setup with roof rack brackets and bars over the glass canopy.
Not sure about other companies but my fiberglass Leer 180 shell has no gutters. Maybe the industrial metal ones have gutters.
For my fiberglass Leer, I found a Trac Rac "Cap Rac" made specifically for mounting to the top of a fiberglass shell. FYI Trac Rac is now owned by Thule. I did have to drill. I recommend affixing painter's tape to the area you will drill - it keeps the fiberglass from cracking. Then I filled the holes, wound around the bolt threads, and placed under the rubberized part of the brackets a nice marine grade sealer as I bolted the racks on.
The racks themselves hold like 800 pounds - well north of what should ever be placed on that roof. The fiberglass shells can probably take about 200 to 400 lbs. I generally use the racks for kayaks. I suppose a roof box could go up there
ThundahBeagle
I have had them on 3 different Super Duty fiber canopies with no problems since 2000. No cracks, no enlarged bolt holes, no issues. Three sets of brackets, three sets of Yakima towers with round bars. Craigslist regularly has the towers and bars for little $$.
Same except no gutters on mine. I've had my racks mounted for YEARS and no cracks. There IS a small bit of bracket on the inside (underside) of the fiberglass as well, helping to stabilize
ThundahBeagle
^^^ Something along these lines. Obviously this is an industrial cap but the Kargomaster ladder rack is what I mean. And can be used with fiberglass cap if you like.
Got my shell and my Trac Rac on CL
Sparse Gray Hackle
Morgan Freeman Imposter
<clip>
The gutter brackets bolt to the sides of the canopy. You can buy them at eTrailer, Rack Attack, etc.. If desired, you could even add stiffeners on the inside of the canopy to put any weight on the bed rail.
Mekcanix
Camper
I run a Leer cap that I picked used a few years ago, and it was built in 2010. I installed rails from a jeep Cherokee and use my Rhino Rack cross bars. I on most camping trips haul a canoe and 2 regular bikes on the rack and have not developed any cracks yet.
I am sure you can tell I am cheap.
I am with you on getting a bigger rig, I have always wanted a power wagon, but they are always way over priced or if reasonably priced of way higher mileage. So I decided to keep the rebel and just make it my way. I try to pack with the limited payload in mind. Thus far we have been able to make it work
John
ThundahBeagle
John
My Leer cap is also used. I am also a cheap basssstard. It was made in 2011 for a GMT900 body, but is sitting for years on my 2014 K2 body k1500 GMC. With a Craigslist-sourced rack. It all works. I do the same. When I built the platform in the back, I forwent the bottom sheet of plywood for weight savings. Other than that, a couple of big backpacks, cooler(s), some tools and gear I didnt weigh it all, but gave a jaundiced eye and a yardstick to my rear rear well clearance.
I try to stay half to 2/3 of total available haul weight, if possible but sometimes it creeps up there to 75 or 80%
I would love a k2500 GMC Sierra but I cannot justify the cost and higher consumption of gas as I use it daily as well
Olde_Kyng
I have noticed a lot of the Tacoma guys are running the A.R.E. DCU caps. I could maybe shed a few pounds if I ditch the tailgate and get the ambulance doors. Only thing is, I would lose my backup camera. Does anyone have any idea about the weight of these? Google says 220 lbs. Does this sound about right? Does anyone have any experience with these?
Henrybrowne
