Crew Cab F800 Marmon Herrington AWD Conversion
M&H
Selling my 1998 Marmon Herrington AWD Crew Cab Ford F800 Conversion with air-engaged Hi/Low AWD
Powertrain: 12v Cummins mated to 6 Speed Manual Eaton Fuller. 48k Original Miles.
I meticulously rebuilt the entire powertrain, with no expense spared using only genuine or superior-to-oem parts, to make the truck fit for travel to extremely remote areas and enhance its performance to my standards. Many might compare this truck to a Stewart and Stevenson or some such medium duty rig, but in my humble opinion it is far superior to those. There are several reasons for this from the comfort of the interior, to ride quality, the 12v P-pump Cummins, & ease of sourcing parts while on the road, etc. but most of all because it is highly capable off-road while also being able to do 75mph down the freeway all day long. It is superior to newer medium duty rigs in that it will outlive them rather easily with its all mechanical/analog systems. I have put about 3000 miles on it since completing the rebuild with a grin ear to ear the whole time. I am selling because my family won't be ready to properly enjoy the truck for another 5-10 years.
The truck is in excellent condition from head to toe and from an era where manufacturers were still in an arms race in pursuing longevity.
The truck has powerful airbrakes and requires NO CDL to drive. It is also properly titled as an RV.
Truck makes ~300hp & 600+ ft/lbs of torque. All of engine the internals/rotating members were balanced in order to make the engine run as smooth as possible. It is the smoothest sounding Cummins I have ever heard. Runs like a sewing machine and cruises like a semi. See below for the full specs of the engine overhaul and living quarters.
Located in Dutchess County, NY
Asking Price: $62,500
The drivers cab interior is in excellent condition and the living quarters resemble a cozy cabin.
Cabin:
  • The living quarters are clad in tongue and groove pine
  • 30Amp shore power Hook-up
  • Water hookup
  • 30 gal. onboard water
  • Full size shower & toilet
  • 10 gallon hot water heater
  • New Webasto EVO 55 17,000 btu diesel heater, with 20 gallon auxiliary fuel tank
  • Gas oven
  • Passageway connecting cab and living quarters
Engine: 12 valve 6BT (5.9L) Cummins, with P7100 Injection Pump​
Condition: Engine was entirely rebuilt. All assembly work done meticulously by me and machine work by a highly trusted machinist. Receipts & video documentation of the entire process.​
Upgrades:
Bottom End:
  • Polished & Balanced Crankshaft
  • Balanced Connecting Rods (both ends)
  • New Main Bearings
  • New Connecting Rod Bearings
  • FluidDampr Crank Balancer
  • Aluminum Piston Oil Squirters
  • Cummins High Flow Oil Pump
  • New Freeze Plugs
  • New Block Heater
  • All Gaskets
Top End:
  • ARP Head Studs
  • New Mahle Pistons (.02 over) - balanced
  • New Head & Genuine Cummins Valves
  • SteedSpeed High Flow Exhaust Manifold
  • All Gaskets
Fuel System:
  • New DDP Stage 1 Injectors
  • 3k P7100 Governor Spring
Cooling System:
  • New Radiator -- All brass, no Plastic.
  • Heater Core -- All Brass (Custom made by BrassWorks in CA)
  • Commercial Grade Radiator Hoses
  • Braided Silicone Heater Hoses
  • All New Temperature Sensors
  • New Thermostat
  • Evans Waterless Coolant
  • All Aluminum Coolant Expansion Tank
  • New Genuine Cummins Water Pump
  • New Freeze Plugs (ALL)
  • New Genuine Cummins Oil Cooler
Transmission:
  • New Clutch rated for 1000 ft/ib torque (Made in France)
    • Clutch pressure plate balanced by machinist
    • Flywheels balanced by machinist
  • New Input Shaft
  • New Input Shaft Seal
  • New Output Shaft Seal
  • Mobile One Synthetic Transmission Fluid (250k mile service life)
Misc:
  • Centramatic Wheel Balancers
  • Isspro EGT gauge
Deleted Member 183
ABSOLUTELY KILLER RIG!!!!
You might want to state the driveline components in your post( axles/ T-case) because I'll bet they are the "top shelf" ********!.
Best of luck with your sale!
M&H
Thank you! I will never find another like it. Hard to let it go. I will get those specs up!
M&H
I have a F700 4x4 that I remotored with a 6BTAA with just the slightest amount of pump modifications ( #10 plate & RPM springs to match the Allison MT653) and it has more than enough power!
I don't think the "ExPo types" give American 4x4 rigs like ours the credit they deserve.
Awesome! The 6bt is a wonderful engine. It's also perfect for overlanding in that Cummins designed the stock internals to handle 680hp. The massive over-engineering was to allow the motor to run safely on the poor quality fuel found in undeveloped countries. Bad fuel causes ill-timed detonation which stresses components. Modern diesels are not so amenable to the "real" world.
M&H
Adding build sheet
  • Like
Reactions: mog
