Pursuing other interests, and no longer using this van for offroad adventures. I’m the sole owner, and worked with Sportsmobile West in Fresno to convert a brand new van to my custom specs; delivered in Feb. 2011. Extremely capable offroad, but never driven on beaches, and never been in an accident. Well maintained, with complete service records and manuals available. No known issues except only one alarm key fob works. Clean title.
Current mileage is 47,293 and is no longer being driven except to keep it in ready-to-go condition. Located in Carlsbad, CA.
Photos and detailed descriptions are in the attached PDF. Please DM me with questions!
Lift raises the floor to 37” off the ground plus full-float axle and Atlas transfer case that enables front or rear 2WD, 4WD High, or 4WD Low (3X gear reduction)
Manual ARB lockers
Frame-mounted Extreme Air Magnum 150 continuous psi compressor with air chucks in both bumpers
Aluminess roof rack with 520 watts of solar panels and 4 Maxtrax recovery boards
Two 4D batteries -- 440 amp-hour (5.3 KWHrs)
Xantrex 2000-watt true sinewave inverter/battery charger
12 AC outlets, 5 12-volt outlets, 3 USB outlets
Bluesky Solar Charge Controller 3024iL, and Solarboost power monitor
Aluminess front bumper with 12,000-pound Warn winch
Aluminess rear bumper with 9,500-pound WARN winch, spare tire, and large storage box
LED lights on the roof rack front and sides, and on the front and rear bumpers
Ultra clean interior has heated front captains’ seats, passenger seat swivels 180 degrees
Rear seat has 3 seatbelts
Olympic Queen size bed (67”W x 79”L)
Ceiling fan
10 interior LED light fixtures, very large storage shelves with cargo nets and 10 cabinets (two with locks)
Brand new, removeable carpet over Loncoin diamond plate floor
Windows screens, dual shades, and black-out curtains
46 gallon gas tank for a range of over 350 miles
16 gallon freshwater tank and a 16-gallon removeable freshwater tank with 12-volt transfer pump
10-gallon grey water tank
Cabinet with Thetford portable toilet
Flat plate water heater
Shower attachment at rear
Radio -- ICOM IC-706 MKIIG 100W HF, 50W VHF, 35W UHF transceiver above the dash with a fixed HF antenna with antenna tuner on the rear driver side and a 2 position (raised/lowered) Diamond VHF/UHF SG7500A antenna on the roof rack over the driver.
Garmin Inreach Explorer+ Satellite communicator for emergency use
Public address system and 50W siren
ODBII monitor/display and DVR mounted on windshield
Train horn
Aug. 2023 appraisal certificate from America’s Automobile Appraisers will be provided to purchaser.
Willing to include gear used with the van such as a Pull Pal recovery sand anchor, chains for all 4 tires, assorted recovery straps, and custom-fitted mattress topper and bedding.
Manual ARB lockers
Ceiling fan
Train horn
