Move bumpers
SkiFreak
Crazy Person
Interesting concept, but given that they do not make any bars specifically shaped for Fuso or Isuzu trucks, I feel that there would be a considerable amount of effort required to make one of these bars fit and to look good.
Maybe I am wrong, but that's my first impression.
The Artisan
Check out my Jeep Jk I installed on my fuso just a little fabrication
Kevin
gator70
The cabovers have a flat frontal configuration. The ford kit is more tapered on left and right. Considering a sizable mounted winch in the front, the differences are less than seen on the first glance. The Isuzu is about 81 inches wide and the American trucks are a few inches narrower. When buying a kit in parts, yet to be welded, addition parts can be fabricated to increase the width.
SkiFreak
Crazy Person
FYI... all of the winch setups I have seen on the Fuso and Isuzu trucks have been mounted in a sturdy steel cradle that is bolted to both chassis rails, not directly to the bumper.
Just sayin'.
gator70
Thanks for the tip - Must consider water build up
gator70
On the other hand - the imported ones are way too inexpensive
Ferjablito
here in Spain in 3mm steel for less than 3000 euros you can't get anything, I would rule out duralumin for a defense
PNWav
