SOLD Custom Built Offroad Camper - Trailtec 4x4 SOLD
Herbc
Located in Glen Allen, VA.
This was built as a prototype at my shop with plans to go into production but it never made it there. It was 2020 and the shop business picked up building rigs so I put it on the back burner and never got back to it. I've used it personally since and it's been great. We are currently building a van and no longer need this or our truck which will be listed in another post.
  • Professionally built by Trailtec 4x4
  • Full steel frame with aluminum skin
  • Camper Box Exterior size 11’ long x 6’ wide x 5’
  • Full length with tongue 15’
  • Height to top of fan 7’-6”
  • Width to outside of tires 6’-6”
  • Interior height closed 5’, open 7’ to highest point
  • Weight approx. 2,900lbs Dry
  • 16" Ground Clearance to frame
Chassis
  • Timbren 3500HD Axle-Less Suspension System with brakes and EZ Lube Hubs
  • Lock n’ Roll Articulating Hitch
  • Falken Wildpeak AT3W 275/70R17 on American Racing Baja wheels, Full size matching spare
  • 2”x3” Tongue extended to mid trailer
  • 2”x2” Floor Framing
  • 1”x1” Wall Framing
  • 4 corner stabilizer jacks
Body
  • Aluminum Skin on walls and roof
  • All doors & hatches built by Challenger Door in Indiana
  • Arctic Tern Windows with screens and blinds
  • Aluminum Tongue Box
  • Overland Vehicle Systems 270 Awning
  • Powertank 10lb Propane Mount
  • Rear Tire/Gear Carrier Platform and Awning Brackets attached to plates welded inside framing.
  • Pullout Kitchen with Isobutane stove, lift-up second level and utensil drawer
  • Pullout fridge slide with Dometic CFX65 refrigerator
  • Exterior access to rear storage compartment
Electrical/Mechanical
  • (2) Renogy 100w solar panels
  • 100ah Renogy Lithium battery
  • Renogy solar charge controller and battery monitor
  • Progressive Dynamics AC/DC Converter and fuse panel
  • 30amp shore power hookup
  • SAE output outside
  • Multiple 12v Sockets/USB connections inside
  • 120v receptacle at AC unit
  • 5k BTU AC window unit
  • MaxxAir Fan Deluxe with remote
  • LED lights inside, on rear, over kitchen, over refrigerator and Red LED “Snake Lights” underneath
  • Thetford cartridge toilet with outside access door for filling and dumping
  • 16 Gallon Fresh Water Tank w/ Spray Port quick disconnect
  • CampLux propane on demand water heater
Interior
  • Rubber “Coin Floor”
  • Split beds with memory foam and anti condensation mats
  • Storage under each bed
  • Multiple cubbies in electrical cabinet & over toilet
  • Tall wardrobe cabinet in rear design to work with 12”x12” packing cubes
  • 1” XPS foam insulation in walls and ceiling
  • 3/16” plywood wall & ceiling panels with marine carpeting
20200502_205906.jpg20240219_114054.jpg20240219_114113.jpg20240219_114230.jpg20240219_114245.jpg20240219_114327.jpg20240219_114354.jpg20240219_114437.jpg20240219_114543.jpg20240219_114736.jpg
syn0s
I don't know why more teardrop/squaredrop trailer manufacturers don't include pop-tops on their models, it seems like such an easy design decision and a good way to increase the interior headroom and even provide additional sleeping area.
Compared to something like a Mission Overland Summit this looks like a down right bargain! Someone should snatch this up!
Herbc
I don't know. It wasn't difficult to add the lifting top vs just welding the top to it.
I had an Intech Flyer before this but we just wanted to stand up and have a bathroom inside so I decided to build this and maybe have a new line of business for the shop. But then, Covid hit and it just became my camper while I built other people's rigs.
whododat
What is the total height of the trailer with top closed?
Also, what kind of beds are in it, cots?
Thank you
Herbc
Thank you
It's 7'-3" to the top of the fan cover.
The beds are plywood with storage underneath. The mattresses are a combo of anticondensation mat, 4" memory foam folding mattresses and another layer of memory foam on top.
Just saw your PM. I'll add some more pics here and try to send them direct too.
DanoWall
