DIY Composite Camper T100 Expedition Vehicle Build
I'm continuing to get questions about the camper, so I made another video. This one is a tour video. I show the various systems in use and talk a bit about the truck.
I do have more projects planned for this vehicle. But I really wanted to drive it around for a while before I start ripping into it again and now my wife's 4runner has been demanding my attention, so stay tuned for more.
Great video! Who are the idiots who thought it would fall apart?! 🤷‍♀️
Haha, Thanks.
I had a handful of people on forums, Instagram, and YouTube commenting that the truck couldn't handle the weight or that my joint work on the camper was not strong enough. But the most popular reason for why the build would fall apart was that I didn't use a captured-spring or some kind of elaborate system to mount the camper to the truck frame. The general assertion was that the first time crossed up the suspension the torsional force would rip the camper apart.
So far my imagineering is proving stronger that their physics 😁
rruff
I think they didn't use any physics... :unsure:
The T100 and the older pickups used a fully boxed frame which is torsionally stiff. You can hard mount campers to that with no worries. The Tacoma and Tundra have had C-channel in the back until recently. Those frames twist a lot, and so if your camper is stiff (and they usually are), the two will fight each other and it probably would cause problems. I used poly isolators with the rear ones on a centerline so they can pivot. It's simple and working great so far. But directly bolting to the camper to the frame is the way to go if you can!
Also I think the edges and joints need a lot less strength than people believe. In Oz I've seen manufacturers join the edges of a sandwich panel with a mere butt joint filled with PU adhesive. They've been doing it a long time, so...
I know it's light, but do you know what the shell of your camper weighed before you did the interior? Do you have any idea what your setup will weigh when you get it loaded for a long trip?
Looking good! (y)
The cabinetry in integrated into the camper, so I kinda built it at the same time I was building the "shell". If I subtract the weight of the bigger items (fridge, toilet, mattress, PV panels) I get 1,156 pounds. I'm guessing if I stripped out all the drawers, drawer slides, plumbing, and electrical the shell would probably around 1000 pounds... maybe a little less.
TroySmith80
Where did you get that hose for the everest stove? I've been looking for something like that and have had the hardest *^&ing time due to the apparent mix of thread sizes out there. That is the camp chef everest stove, right?
awesome camper!!!
TroySmith80
thanks for the link. When I went there Amazon actually showed that I had ordered that a year ago, and I returned it. I've had a hell of a time with this. There are multiple versions of thread sizing and pitch out there and that one did not fit my camp chef Everest. That same stove is made by Stansport or at least very very similar, it uses a lot of the same stamped metal and everything but it has a different thread attachment. The one you linked doesn't work with my stove. I've put hours of my life into trying to figure that out, and i want them back! lol. I guess at this point i should junk the damn stove and get whatever is the more common version.
I guess CampChef must have changed the fitting at some point. Mine is 8 + years old. Glad you didn't order it again. Sorry I wasn't helpful
off_to
