Big Booty Judy - 2014 DC Tundra Build w OVRLND Camper
dirtnsmores
So, I've run True-tracs and Auburns in different vehicles over the years, and wasn't really a fan of the Auburns with how they wear, but the Powertrax GripPro is fairly close to the TT. Its a true helical cut gear driven LSD and I LOVE it! I do turn the "auto LSD" off when I drive these days, but that's it.
good to know thanks! I think the TT is available for my first gen Tundra if I decide to get rid of the mechanical limited slip toyota has in here
Fergie
I bought a shitbox 2003 accord late last year, gets 30mpg vs the 10mpg in the truck around town, so the truck has just seen snowstorm duty this winter.
The other day, I picked up a practically brand new set of CaliRaised bed stiffeners and installed them....such an easy install, and didnt have to modify the existing extruded aluminum build. Had to notch the bed rug a bit, and glued the portion down w some 3M.
I also finally finished the insulation in the roof; Jay/Maggie and crew are going to be installing the headliner in a few weeks:
ThePartyWagon
Sold the Habitat, and am awaiting a Camp Ovrlnd topper in a few months. Took my last trip in it a few weeks back, my buddy and his GF came down from SLC to try and complete our AZ Wild Trout Challenge...we got skunked on native brooks and on the Apache...winds in the 40-50mpg range made casting damn near impossible on these small waters. Best part was all three getting the Gila.
Is that Brian I see?
Fergie
Went to the local pick and pull since they had a 2012; thought I'd pull the OEM CVs, but the axle nuts were seized, so that was a no-go. Ended up grabbing the DS grab handle and the overhead console.
Not bad for $6 for the for the grab handle, and no wait time.
Spent another $11 picking up the capture nut(only could buy a pack of them) from Napa.
Also picked up new visors for my 2003 Accord shitbox. And grabbed the ABS sensor from the 2012 to have a spare.
Monday, I went back out to the pick and pull to grab the two extra screw retainers....cost me the $2 entry fee and they gave me the two fasteners for free, so, the cost of gas essentially.
A word of advice....dont accidentally cut the rear light wiring as it will blow the 7.5A fuse in the engine bay....I taped the cut wires up and tucked them away.
There are three sets of retainers, the middle ones can be removed easily...not the others. Found the screws I needed too, so that was cool.
This one was snapped before final tightening...and after replacing the fuse...
I swapped over the old LEDs I had installed, and everything is GTG.
Fergie
For everyone asking about wind noise...it really isn't bad. A few years back in the White Mountains, the Hab was terrible, but with wind gusts at +40, working in the camper was mellow.
I had OvrLnd add the headliner a bit back, and it was incredibly easy to add the daisy chain loops in since I can't loop anything over the struts like before. Used the trusted Harbor Freight rivet installer, and called it good.
ac
shmabs
Do you have the part number for those captured nut things from napa?
Fergie
I finally got around to making a drop down table for the camper. On Jay's advice, I VHB'd the aluminum unistrut to the skin and through-bolted the assembly.
Should work well for a prep table for lunch; I'll build a 8020 box on the inside to hold utensils and things like that. I think it came out alright.
Fergie
Over the weekend, finally got around to replacing the tailgate hinge since the bushing was completely gone. Sadly, the soft drop still doesn't work well.
The lower bolt came out just fine, but the upper bolt took some persuasion...ultimately a dremel, induction heater and cold chisel did the trick.
I have a Mountain Hatch tailgate plate that adds enough weight that more help was needed. I ordered the Rough Country kit, and initially installed it on the PS of the tailgate. My reasoning was to distribute the load on bother sides, since the DS already had the factory strut. Well...that didn't work because of the notch in the PS hinge that allows you to remove the tailgate. No problem, swapped everything to the DS.
You have to start them young in their hatred for Torx head fasteners. Told the boy to grab the Torx, and he came back with my old VW set of triple squares, so I let him try those a few times before I corrected him.
All in all, happy w the mod.
Fergie
I got rid of a squeaking squirrel cage seen here, with the new TLC version...super easy project.
I relocated the factory rear camera with a super ghetto version:
I've got an 813 Fab bracket on the way: https://813fabrication.com/products...4OQoLJtU3y9EHUt5dyWeN17i6oWN9FvJe1F4BFCgYEJoU
Can't use it as it was intended as the canopy is in the way:
So, it'll go on the RIGD swing out.
Easy enough to pull the camera and harness from the tailgate and extended the loom with this:
Thanks to Tundras member Sea Weathered for the idea and link to the wiring. No need to spend +$225 for a new camera when the wire and bracket are less than $100 all said and done.
Fergie
Did you notice any improvement in air flow?
Seat of the pants....or breeze of the pants, yes. I noticed it mainly on split level functions like defrost and feet, or chest and feet. It is also far quieter and is faster to spool up. If mine hadnt been squeaking, it wouldnt have been replaced, but there were some good Christmas deals from the online Toyo dealers, so why not.
Fergie
Finally got up to UT and back on the water w my brother from another mother. The trip was pretty damn windy this last weekend, with sustained at 40mph and gusts even higher, but we found some rock outcroppings to hunker down near, and they blocked the wind a bit. First spot the hatch had already happened so the fish weren't looking too hard for food as they had plenty. The first was the largest of the weekend:
And at the second spot, at higher elevation, the number of fish were too numerous to document. Some stockers and natural reproducing bows, a cutty here and there and one tiger. Lots of "two fish one net." Easily 50 fish each over the weekend, and that was plenty good for me.
Glad to have had the propex up and running as overnight temps were in the 20s the second night, and 30s the first. Kept the camper at a toasty temp. Had some good beers and an a solid old fashioned w fig infused bourbon, black walnut bitters, a bit of smoke, and bourbon infused fig chunks(instead of cherries).
Kevinm
Any water intrusion issues between the tailgate and barn doors? Im considering building a canopy with that style doors but i doubt i can make it very waterproof and i foresee issues getting out when snow/ice have frozen on tailgate lip
Henrybrowne
