HoneyBadger Farm Truck Build
SSF556
SE Expedition Society
Well time to turn the farm truck into something a little cooler.
2012 Ram 3500 Diesel that I purchased back in 2019 from a member here at Expo.
Current setup
PowerWagon wheels with 285/75/17 Coopers
AEV mudflaps
Kore level kit with Bilstein
Rear Airbags
ARB Modular Front Bumper
Warn 16.5 with synthetic rope
First big add is an ARB front bumper with a WARN 16.5 synthetic. Thanks to @Kingsize24 for answering all my text messages about the ARB bumper.
Also ordered a complete set of Asfir underbody protection.
Future Projects
ARB rear air locker
llamalander
Get out the hole saw!
To which I would add, cutting big holes in curved sheetmetal doesn't always go as planned-- if you can glue a small (3/4"-1") block of oak/maple/hardwood on to hold the pilot bit, then go real slow, you are much less likely to wander...
Block can go in inside or outside the fender, use PL or another multi-surface glue and let it fully cure, make sure your pilot bit is well in it before the teeth touch your paint.
SSF556
Thanks for the heads up. I bought before it went out of production. So no real plans right this moment to install it.
oskarf150
