International 4700 Ambo build
Baloo
"The Bear Necessities"
Time for a long overdue update, replaced rear wheel bearings and axle seals.
Baloo
3 gallons of gear takes for ever to pump in when it is cold out.
Deleted Member 183
I suspect that your truck has stud rather than hub pilot axles...
If that is the case then it is VERY IMPORTANT that you chamfer the holes on the inside of your M35A3 rims for your back axle and spare!!!!!!!
  • Like
Reactions: mog
Baloo
Time for a change. The past 11 years of Ambo driving have been awesome. In the search for 4x4 parts to convert the International to a 4x4 I stumbled across a poor little Oshkosh P-19 in need of a new home. Why a P-19 you may be asking? Biggest reason for me is why not? It is road legal and titled, a great engine (Cummins NTC-400 big cam 3), and it just looks cool. It will be a slow start as parts have been ordered and it is at a buddy's shop. Once it makes it way home, things will pick up and the fire fighting equipment will be removed. I will be starting a new thread to document it's progress.
Sent from my SM-F946U using Tapatalk
gp01
