Post pictures of your Land Rover.
A.J.M
My new to me 2016 Discovery 4 landmark.
A worthy successor to my much loved Discovery 3 which has sadly gone to Land Rover heaven.
Will be fitting the complete Prospeed off road armour, front runner roof rack and Safari snorkel from the 3 to the 4.
Then will get a set of 18s for off road tyres and leave the 20” wheels are regular use ones.
RealTruck
Supporting Sponsor / Approved Vendor
A great find! Can't wait to see it all decked out in the new gear!
rgallant
Side bay on the west coast of Vancouver Island, the old girl is still plodding along. 04 Discovery II
morrisdl
Pretty much how it looks when I don't drive it for a few days :confused:
You have a slow air leak somewhere. The LR3 wakes up every few hours and relevels the truck by letting air out of the corners that are higher than the leaking one.
If you dont fix it soon, the aircompressor will wear out in a few months and be a much bigger repair bill.
Spray bottle of very soappy water is good for finding leaks, but often these are in the front and rear valve blocks.
You can start/repressurize system, then shutoff engine and pull a couple fuses or leave a door cracked open overnight and see if the front, rear, or a single corner drops.
Sorry, I forget which fuses but im sure you can search it.
Id start with replacing those vavle blocks if they havnt already withing the last 60k miles.
ALSO, i suspect the vavle blocks chronically get clogged with dessicant dust. The dessicant air dryer pellet cannister is attached to the compressor and vibrated into fine powder. Replace those little bead and clean out the canister too. IF you want to drive this LR3 "forever" Id find a way to move/mount the dryer canister off the compressor.
Gnomad
We had his and hers LR3's for a few years, until she sold hers for the down on a Bronco Sport that she bought after seeing a test mule that Jim Farley was gassing up, and I sold mine for a 6G 2 door. That was fine for a couple years but once a Rover person it seems the siren call never goes away. Now she has a Disco Sport and I'm back in a LR3.
V45W_Proto2.5
