Maybe a bit small for what you want but this Ammo box Firepit from another thread looks like a nice solution.
![DSCN8259[1].jpg DSCN8259[1].jpg](https://expeditionportal.com/forum/data/attachments/357/357284-8ce8d8767b6cfcedde38d41f0e77ae71.jpg)
I have been using a Volcano for everything. Wood fire when able charcoal when able and propane for when we have fire restrictions. They work great as a fire pit.
https://volcanogrills.com/
Check out these flat pack grills. It would be easy to pull the grill off and use it for a fire pit
https://www.amazon.com/Flatpack-Portable-Stainless-Steel-Grill/dp/B01HZF9FMG/?tag=popularmechanics_auto-append-20&ascsubtag=[artid|10060.g.1331[src|[ch|
Galvanized trashcan lid. The 1/2" aluminum tubing has 1/16th inch holes drilled every 2 inches to let the propane out and the end is hammered flat. The aluminum tubing is held to the pan by 1/2" Electrical Metallic Tube (EMT) fasteners. I'm sure length of of the straight part could be half what is shown to make a more compact design.
I've got one of those foldable firepits, be aware they're pretty small, 13" on their long side. So your usual gas station bundle of firewood may barely fit or be a bit too long. You'll need to split all your wood into small bits and have a small fire. Good for ambiance, but not much else. Even as a wood fired grill they're not great (but briquettes work decent).Those look GREAT! I've never seen that before. I just put one in my Amazon cart. Thanks!
One of my biggest pet peeves is arriving at a campsite and finding that the fireplace is in a weird unworkable place, so no fire. This will solve that problem! I like that you could have a fire for ambiance, heat, or cooking using very little wood. Split pine kindling would work well with this.
Awesome work right there buddy. Would be great on the river. Bookmarking this.Well 6 years has taken its toll on my original DIY propane fire pit.
This time I took the easy way:
Which meant using a 90 fitting through a hole in the bottom instead.
The valve isn't necessary but I had it on hand so wanted to try it out.
The new burner has twice as many holes so distributes the flame better than the old one.
Anza Borrego National Park requires all fires in a metal container so it can in hand over spring break where we used it almost every night.
www.tripodtorch.com
I made an ammo can LP fire box on the cheap that works great. Had to strip / burn off the paint. Nice to have in Cali when the summers won't allow wood fires.old thread but new solutions lol
We have fire restrictions here most of summer so I opted for propane, This thing is small but puts the power out. However it does get sooted up after use (threw gloves in the carry bag)
Tripod Torch
Tripod Torch is the ultimate portable propane fire pit for camping, overlanding, and outdoor adventures. Compact, lightweight, and comes with a lifetime guarantee, its patent-pending vertical burner delivers efficient Heat to Your Seat. Fire ban compliant and durable, and made in the USA! Free...www.tripodtorch.com
I have tried so many different setups. I always go back to my SnowPeak. It just works.In Anza Borrego desert, camp fires have to be in a metal container with a bottom. Looking for creative ideas.
What I want
- something dual purpose
- collapsible would be great, but not required if its very useful as something else
- Low walls
Ideas I've found
- washing machine drum (too big, walls too high)
- turkey pot (pretty good idea, but bulky)
- Wash tub from home depot (galvanized - I've read this is bad on health)
