2016 Chevy Silverado LTZ Z71
D45
Another oil change
New front and rear rotors and pads
Just had the transmission pan dropped for a new filter and fresh fluid
The service brake assist (or something) light at low speed or low idle is very annoying .....Zero brake pressure and have to throw the trans in neutral
I heard it's a recall need to look into that
100,000 miles on the truck
D45
I test drove a 2021 nicely equipped Chevrolet Silverado Trail Boss tonight
38,000 miles for 42k
In park and idling, I crawled under the truck there was a consecutive double tick coming from the bottom end of the 5.3L motor
The $975 factory option side steps were missing
They offered me 20k trade in for my 2016
I laughed and walked away
Kingsize24
Damn!!! I would have too!
D45
Had to order a front wheel stud......$3 for a Dorman brand
One stud broke in half rotating the tires, never seen this before
Hopefully it'd not a PITA to replace it, but I'm not paying a shop $150 to replace a $3 part
D45
295/65R18 : 33.10 x 11.80
275/70R18 : 33.10 - 33.20 x 10.80 - 11.00
Hankook Dynpro is 33.10 x 10.80 in the 275/70
I would most likely find a good used 275/70 tire also so it should be spot on with the diameter of the 295/65
I've been pushing my luck and and going on a 500 miles trip next month
I need to get a spare for peace of mind, to match the height of the tires I'm running:
295/65R18 Duratrac that is:
33.10 x 11.80
The spare tire can be more narrow as long as it fits the factory spare wheel
Spare is a 17" ; P265/70R17 .....so I need to find a 17" tire to most closely match the 295/65R18
D45
I think I found a 17" tire size that is spot on to the 295/65R18 size
255/80R17 which is 33.10" x 10"
D45
Replaced in under 30 minutes total job
Old stud came out in 3 hits
D45
February 2021 the Duratracs were installed
I'll probably get new tires this fall, before winter hits.....tread is still good, just starting to wear fast and get loud
Tires are getting rotated and balanced Friday.......have 106,000 miles on the truck currently
D45
I also learned that Goodyear discontinued the Duratrac in the current tire size I'm using:
295/65R18
I could find other manufacturers in this size or explore the other size I was also initially considering: 285/70R18
275/70R18 : 33.60 x 11.10
D45
These current Duratracs have 40,000 miles on them
It looks like another 5,000 miles and I'll get new tires, this fall
The Duratracs (20") on my old F150 lasted alot longer
D45
I wouldn't be opposed to changing the tire size either
Truck has like 106,000 miles on it, just did another oil change. Amazon deal days had full synthetic oil cheap
Had to also buy a new antenna, lost it in a car wash . Haha
D45
Stock size : 265/65R18; 31.6" x 10.40"
Currently running 295/65R18 with ZERO rubbing
285/65R18; 32.60" X 11.20"
305/65R18; 33.60" X 12.00"
295/65R18; 33.10" X 11.60"
295/70R18; 34.3 " x 11.60"
285/65R18; 32.6" X 11.20"
285/70R18; 33.70" x 11.20"
I really do not want anything over 34" tall
Will a 12" wide tire clear?
dhuss
