SOLD -2022 Rivian R1T Quad Motor w/ Roofnest Condor Overland 2 RTT
NYLASurf
I am listing my Rivian 2022 Rivian R1T Quad Motor Launch Edition. For those that dont know...Basic specs and dimensions are: 800 Hp/826 TQ means 0-60 in 3 seconds. 135kw battery translates to 300 miles between charges. Adjustable air suspension raises between 9.4 to 14.6 inches of ground clearance and rides on 20" all terrain tires. Kinetic roll control (hydraulic cross linked suspension similar to McClaren) means no roll bars to disconnect. 217.1" in length, 135.8" wheelbase, 81.8" mirrors folded and 78.3" in height. Cargo capacity is split between the front trunk (Frunk), gear tunnel, and bed area. Frunk: 31.5 liters, Gear tunnel: 337 liters and additional 95 liters under rear bench seat. Bed dimensions are:
  • Bed length at rail: Tailgate Up 54.1 inches/1373 mm
  • Bed length at floor: Tailgate down 83.9 inches/2130 mm
  • Bed width (exposed cargo width): 51.1 inches/1299 mm
  • Bed height (tonneau open): 18.3 inches/465 mm
  • Bed height (tonneau closed): 17.1 inches/434 mm
  • Bed volume: 29.2 cubic feet/828 liters
Water Fording depth - 1 meter
Approach angle in Offroad mode 35.5 degrees
Departure angle in Offroad mode 30 degrees
Ramp Breakover angle in Offroad mode 26.4 degrees
Max Climb Gradient 45 degrees
This vehicle is a Launch edition in Launch Green exterior (only time it was offered in this color) with Ocean Coast interior (rare combination).
Mileage is currently 19,630 miles.
Factory Features
Powered Tonneau cover (factory upgrade to new version w/two motors)
heated and ventilated front seats with power lumbar control
heated steering wheel
Six front row and two side curtain airbags
Electronic stability Control and traction control
Adaptive cruise control
Lane keep assist
Lane departure warning
Blind spot warning in mirrors with side camera displayed in driver display
Cross traffic display
automatic emergency braking
Tow Hooks
onboard air compressor
Large battery pack (135KW)
2 set Rivian crossbars
Gear Guard Cable
Vehicle key set includes Carabiner key, two RFID cards, and RFID activity bracelet
Additional Accessories and upgrades
Rivian fitted all weather floor mats (yellow logo)
Rivian extra long gear Guard cable
Rivian First Aid Kit (fitted Front door)
Rivian air compressor accessory hose kit
Abstract Ocean high intensity LED lights in Frunk (white) and gear tunnel (amber)
Abstract Ocean Panoramic Roof Sunshade
Abstract Ocean Silicone Tow Hook covers
Abstract Ocean vinyl b pillar, rear bed and frunk decals in Rivian Yellow
Abstract Ocean vinyl wheel decals in yellow (unused)
TWraps Gear Tunnel sill wrap in Yellow (Carbon black unused also included)
TWraps Matte screen protectors for Driver Center and rear interior screenTWraps center console organizer
Xpel Fusion ceramic Paint Protection film wrap on whole vehicle
Heatshield gold windshield/Side windows/rear window/panoramic roof sunshades
Roofnest Condor 2 Overland roof top tent with crossbars
Roofnest Condor 2 annex with sidewalls, floor, and mini room (unused)
Roofnest Condor 2 wall Insulation kit (unused)
Fitted Rubber Frunk/Gear tunnel/Bed floor liners
10 gallon frunk fresh water tank with 12v pump
Vehicle is completely wrapped in Xpel Paint protection film, Amber film on fog lights, silicone covers on the tow hooks. Frunk, gear tunnel and bed mats, Amber and Bright white LED bulbs in Frunk and Gear tunnel, matt screen protectors on all Interior screens.
This is an incredible vehicle for overlanding, besides the Roofnest RTT and the frunk mounted water tank with hose and pump, the vehicle's 2000w inverter powers 2 110 volt outlets in the bed, an additional one in the Gear tunnel as well as in the cab. Additionally, there are multiple 12v outlets in the cab, the gear tunnel, and in the frunk (this 12v went away after 2022 year). Factory onboard air compressor is accessed in the bed, powered tonneau cover retracts fully behind the bed (i have the updated 2 motor replacement). You will not find a better kept, like new Rivian and it comes with the remainder of factory 5 yr/60,000 mi basic, 8 yr/175,000 mi powertrain warranty.
Asking $67,500
NYLASurf
Interior photos
NYLASurf
Next week I will take some additional photos of all the accessories that are boxed. Most of my adventuring has been light fire roads, weekend camping at state/national parks only requiring the tent to go up.
NYLASurf
I wanted to follow up and include the updated photos of the RTT accessories as well as the Frunk mounted water tank.
LRNAD90
I'm sure someone will be gaga about it, but let's be realistic, 7,148 lb curb weight, 0-60 in 3 seconds and 300 miles between charges (good luck finding the next charger if you are actually overlanding) are not generally the specifications someone looking for an overland rig needs (or even desires).
Road tripping between charger equipped camp sites maybe..
NYLASurf
@LRNAD90 - you are correct given charging infrastructure currently, hoping solar panel efficiency increases in the future to allow for some meaningful range gains when camped for a while "Incredible" was referring to all of the from the factory specifications.
