1998 Stewart & Stevenson M1088 Armored 6x6 Semi Tractor Truck
mog
Kodiak Buckaroo
One of you certainly needs/wants this.
- 32,790 Original Miles
- Cat 3116 Turbocharged Diesel Engine
- Allison 7 Speed Automatic Transmission
- Fully Armored Cab ( 2"+ Thick Ballistic Glass & Armor)
- HD Ring Mount Gunner System
- Heated & Cooled Cabin
Seating for 3 and even 'on-sale' at $199k
Sweet talk Andreas at Total Composite to do a run of panels with ballistic inserts for your habitat and you would be golden for a 'bulletproof-build'. ;)
Disclaimer - no relationship with this vehicle, Midwest Military Equipment, or Total Composite
Czechsix
Watching you from a ridge. In Alaska. I'm cold.
Driver: "get a shovel"
Co-driver: "I'm not the one that got us stuck, why don't you get a shovel yourself?"
M2wzUmdtbzVieGs9
It's perfectly set up for a fifth wheel, I vote Mog should get it and hook up that toy hauler he's always wanted - one that'll fit the Power Wagon/GZL.
PNWDad
Dad in the streets, Daddy in the sheets
Played around with level 8 armored fiberglass panel the other day on a jobsite. It was 1.5 inches thick and solid. Like solid resin with many, many thin layers. Crazy heavy stuff took a machine to lift a panel. Guys said it was over 2 grand a pop and there were stacks of it. It's fire rated too.
  • Like
Reactions: mog
gator70
Military trucks that have very little use, sat in the Texas heat for 25 years unused. All hydraulic lines and wiring looms need replacement due to heat/age damage.
More important, like earlier Unimogs air brakes often have problems.
In addition theses trucks came with a number of technical features that break often and could be deemed not a requirement for expedition vehicles.
V45W_Proto2.5
