badm0t0rfinger's 2014 Raptor build
badm0t0rfinger
Raptor Apologist.
Thank you all! so I got a bit of a concerning message from REDACTED and they were worried that I had received the wrong shocks because I had posted that I went to "stage 4" because my truck already had the RXT leaf springs from ICON, and when I started spec-ing out the build with the shop we had agreed that it would be best to go with the stage 3 as we were under the assumption the main difference between the S3 and S4 was the inclusion of the the leaf spring, however that is not the case. Stage 4 has a different rear shocks, so when I posted I had a stage 4 they were obviously concerned because they wanted to make sure I didn't receive the wrong parts. So now I'm shitttt should I get the stage 4 rear shocks too?
Anyways, if any of you are in Florida and want Gen1 Ford Raptor pull off suspension parts, Gen1 Beadlock rims or beadlock rings, or titanium lugnuts drop me a line.
badm0t0rfinger
Raptor Apologist.
Also much smaller project but after trying to back up the trailer in the most pitch black dark of night I picked this harness up.
It goes in between the 7 pin trailer plug harness and the faceplate so it should be plug and play. I really only want it for reverse lights but should also work for turn signals so I'll just shoot the line and make the bulb for reverse amber or white and the bulb for turning and brakes red.
Houie
