1989 F150 4x4 4.9 ZF5 w/Caravan Campershell PRICE REDUCE
Testing the waters. Basically needed more seats....bigger dog :)
1989 F150 Custom 4x4 4.9 ZF5
CALIFORNIA SMOGGED 1/30/25 GOOD FOR 90 DAYS
Started building this truck in 2019. Dont know much of the history on the truck. Never carfax'd it. Anyways its pretty clean for what it is. Origional paint. It does have trail bruising which will be shown below. Ive done everything you could do to these trucks that makes it worth what im "asking". I will list below.
Engine (Normal maintenance stuff. Pretty much the only thing I havent really touched. Its a Ford 300. You cant break em.)
  • Motorcraft PLugs
  • Motorcraft Wires
  • Motorcraft Cap n Rotor
  • MSD Blaster Coil(previous owner)
  • Odessey Extreme Battery
  • Upgraded 3G High Output Alternator
  • Aftermarket Terminals
  • All new A/C conversion. Literally blows cold.
  • Fel Pro Timing Cover Gasket
  • Napa Water Pump
  • Napa Thermostat Housing
  • Motorad Thermostat
  • eBay Temp Sending Neck
  • eBay Smog Pump Check Valve
  • Motorcraft Clutch Master
  • Econoline Saginaw Power Steering Pump Conversion
  • Melling Oil Pump
  • Melling Oil Pickup
  • Felpro Oil Pan Gasket
  • High Pressure Fuel Pump
  • Fuel Filter
Exhaust
  • Professionally Done 3" Cat Back Flowmaster 40
Transmission/T-Case
  • ZF5 swap
  • ZF5 fully rebuilt by a ZF5 professional. Spent over $2k on the rebuild. These transmissions in a small block bell housing are nearly impossible to find. Granny 1st and a lower reverse makes this thing a tractor when you want it. Runs Penzoil Syncromesh. Shifts like glass.
  • Luk Larger Flywheel
  • Luk Clutch/Pressure Plate
  • Luk Slave Cylinder and Throw Out Bearing
  • BW1356 Custom T-Case
  • Fully rebuilt hybrid I did myself. Front half of case is original to truck and the rear is from a 94 Bronco. I had the rear stub machined to accept the speedo drive from a local machinist.
  • Flange style rear output to accept Double Cardan
  • Fixed known oil pump drive issue by welding a rod to the end of it so it would not wear through the case anymore.
Drivetrain
  • Custom rear driveshaft. 1350 Double Cardan to splined slip joint. 1330 U-Joint to differential.
  • Custom front driveshaft. 1330 U-Joints on both ends.
  • Both shafts balanced and fabricated by a professional. When I purchased them he said I could "lay the whole truck" on them. The 1330 U-Joints were designed to be the weak point of the drivetrain.
Rear Differential
  • Ford 8.8 Original to truck
  • 4.56 Ring and Pinion(done by WFO)
  • All new bearings and seals.
  • Factory TracLok with aggressive clutch orientation.
  • Sierra Gear and Axle Shafts
  • All new Raybestos brake assembly(Drums, shoes, cylinder..etc)
  • Stainless extended brake line.
Front Differential
  • Dana 44
  • TracLok
  • All U-Joints replaced
  • Spring added to slip joint along with welded retainer cap.
  • Raybestos Calipers, Pads, Rotors, Bearings
  • Stainless extended brake lines.
  • Warm Premium locking hubs
Rear Suspension
  • Deaver J40 Leaf Springs
  • Bilstein 5100's
  • Custom Stock Length Shackles with Delrin bushings
  • Factory 4WD lift block retained.
  • U Bolts / WFO Plates
Front Suspension
  • Desolate Cut and Turned Beams
  • ProComp Explorer 4' Coils
  • 4 Bilstein 5100 Shocks
  • Skyjacker Radius Arms
  • WFO Limit Straps
Steering
  • Desolate Heavy Duty Steering Link
  • Mevotech Ball Joints
  • Red Head Steering Box
  • Napa Saginaw Power Steering Pump w/Cooler
  • Desolate Mid Drop Arm
Wheels/Tires
  • ProComp 16x8 Steelies
  • 315/75r16 Falken Wildpeak AT3's
Accessories
  • Warn Winch Bumper
  • 12k Warn Winch
  • KC Daylighter Spotlights
  • Rock Sliders
  • Rear Swing Out Bumper(Had it built with an extra hitch on the swing out for bicycles. Swing out parts from RuffStuff. Wavian Fuel Can.)
  • NOS Ford Bug Shield
  • Window Shields
  • CB 102" Whip Antenna
  • Bandit Noise Filter
  • Tuned Cobra CB
  • New Headlights and Bezels
  • New Emblems
  • Painted the interior of the grill with bed-liner.
  • RAM Hard Mounted phone holder
  • Dash Carpet Cover
  • 12v USB Outlets with display
Caravan Camper
  • Full restore. Removed windows and painted to match. Decals done by a professional. Even got the original Caravan Camper Shell decals from the manufacture.
  • Door Rust repaired with new insulation.
  • Painted Boat Rails with new hardware.
  • Sand blasted rust spots on the interior.
  • Interior painted.
  • New shell seal.
  • Resealed Sliding Windows
  • Maxxair Vent and fan. (Cant seem to seal it myself. Even had a friend build me a custom poly spacer. Works but leaks)
  • ARB Awning with light. (Light recently stopped working. I warrantied one already.)
  • Custom bug net for door.
  • New door seal and re-worked latch.
12v System
  • 2 100 Amp Hour WindyNation Batteries
  • 2 100w Renogy Panels
  • Renogy Rover Elite w/Bluetooth Connection
  • 2000w Inverter
  • Camper Lights
  • Exterior 12v Socket for awning
  • Power Box with switches and volt read-out.
  • All fuses and switches are Blue Sea
Bed Platform
  • Drawer system built by local woodworker.
  • Millard mattress.
  • Storage doors.
  • Painted before installed.
This truck has seen alot of adventure. From snow wheeling to two completed trips through the Rubicon to trips to yellostone and death valley. It will get you anywhere you want to get a fullsized rig through. Its never been denied in the snow. Does 65mph at 2200RPM and crawls when you want. This truck is amazing and took alot of work to build. Dont get me wrong I have used and abused this truck but always spent my weeknights and weekends maintaining it. Its a work of art but we no longer use it. Im sad to even think about letting it go but its time to move on. If you have any questions please feel free to ask. Ive touched almost every bolt on this truck to get it to where it is. I have receipts for just about everything. Im currently trying to snuff out a vacumm leak for the climate control. Currently stuck on defrost. Thank you for your time.
Asking $18,000 $16,000 $14,000 OBO
Pictures below are from trips over the years.
Mickey Bitsko
It's hard to believe this hasn't sold, for what it is, it's cheap compared
to some on here that are 1/2 the size, extremely overloaded and 4 times the money..
Hasn't reached cult status I suppose..
W_b, maybe there's better market elsewhere?
Should have posted camper photos from the start. Seems to be the first question i get.
Battle
This thing is epic - I've wanted to build a 4.9 F-150 like this for years - thanks for the inspiration. I'd buy it if I wasn't on the other side of the country - GLWS.
Fergie
Thats just a damn good looking truck and camper. 5 years ago me would have bought this for my flyfishing rig and cruised to MT/WY/ID for a summer.
The camper is sweet too; love the large single door and simple build out.
Def GLWS man. Nice rig.
