**SOLD** 2020 OEV Backcountry (Camp-X) Truck Camper in Denver, CO - $32k
Crux
The Overland Explorer Vehicle Backcountry / Camp-X is truly one of the best truck campers available. Built to withstand tough conditions, it's both durable and incredibly lightweight at just 1,210 lbs. This camper performs exceptionally well year-round, including in extreme winter temperatures (-17°F at 10,000 feet, and it stayed warm and cozy). I’m the original owner, and the only reason for selling is to upgrade to another OEV camper. Note: if you want to use the included torklift derringer tie-downs you will need to purchase and install the OEV mounting kit on your truck. Otherwise you can use heavy-duty ratchet straps.
Located near Denver, CO
2020 Camp-X 6.85 - Specifications
• Pop-up Roof with Gas Struts Assist for Lift
• Removable Cabin for 3-4 Seasons
• Sleeps up to Four - has king size bed
• Ext. Dimensions (Closed): 140” L x 81.5” W x 62” H / (Open): 84” H
• Internal Dimensions (Open): 137” L x 74.5” W x 82” H
• Constructed with Powder-Coated Aluminum Extrusions
• OEV Composite Floor, Walls, and Roof (R-value of 8 or less)
• Fire-Rated Insulated Four-Layer Soft Wall (R-value of 4 or less)
• Locking Roof Support/Hinges at Both Front and Back
• Equipped with DOT LED Lighting
• Designed to Fit Factory 1/2, 3/4, and 1-ton Trucks
• Dry Weight: 1210lbs (Excludes Jacks and Batteries)
• Wiring Harness for DC to DC Charging
Camper - Plumbing, Heating and Cooling
• Truma Aquago On-Demand Hot Water
• Truma Vario Cabin Air Heater
• Multi Speed Roof Vent W/Roller Blind
• 20-gal Freshwater Tank W/12v Pump and LED Backlit Tank Level Site Window
• Sagiv Outside Shower Connection
• Stainless Steel Sink w/Flush Mount Glass Top w/Upgraded Long Neck Faucet
• Stainless Steel Cooktop w/Cast Grill
• Dual 10lb propane tanks - easy to swap if you run out
Camper - Electrical
• USB Plugs (Type A)
• 12v Auxiliary Connection Outlet
• Rear Porch Light
• LED Interior Dimmable Lighting
• Redarc Manager 30 w/display for AC, DC, and Solar inputs
• 200w Solar Panel
• Dot Exterior Lighting
• Group 31 battery tray
• New 100ah AGM battery
Camper - Other
• Large Dometic Dual Pane Acrylic Side window with Blind and Screen
• Screen Door
• Entrance Door Grab Handle
• C-shaped Dinette - Folds down into Bed 38”x77”
• Cabinet to house porta-potti or other toilet
• 4” Medium Density Foam Dinette Cushions
• 4” Combination Soft/Med Density Mattress W/Removable Padded Cover
• High Traffic Grade Lonseal Vinyl Flooring (plus custom cut carpet)
• Structural Powder Coated Aluminum Interior Cabinetry W/Polymer Doors and Cast Aluminum Positive Close Latches
• Awning Mounting Brackets
• Outside Shower Enclosure Mounting Brackets
• Fire Extinguisher
• Smoke, LP/Co Detectors
• 4 Reico Manual Jacks w/2 Handles
• 4 AnchorGuard Derringer TorkLifts tie downs ensure the camper does not move
Camper - Upgrades
• Dometic CRX65 Built-in Fridge
• King bed extension including extra mattress section
• Front light bar
• Rear molle racks
• Includes roof rack bars (2) on L-Track
• Rear molle mounted folding jump steps (2)
Known Issues:
• Minor scratches/pin-stripping on camper and camper window (see pics)
• Window shade is separating a bit in corner
• A couple rivets at the front mounting location were worn down before the rubber puck installation, but this does not impact the structural integrity
Crux
More photos
Crux
More photos
gp01
