Are Isuzu and Fuso wheels interchangeable?
Looking for a spare wheel for our 07 Fuso FG (6 lug). Are the Isuzu 6 lugs interchangeable? The bolt pattern seems to match from what info I’ve gathered but want to confirm they’re identical in all aspects
SkiFreak
Crazy Person
Can we mix and match them
Mix and match them with what?
As mentioned already, the offsets are different between the Isuzu and the Fuso, so super singles need to be for the specific make if you want the track to be the same on the front and rear.
Edit:
If you are unfamiliar with these super singles...
The same rim is used for both front and rear. The front in mounted on the deep side of the rim and the rear is mounted on the shallow side of the rim.
The rim offset is what allows for the track to be the same front and rear.
PNWav
