Energy Efficient food prep: sous vide all in one method.
Dave in AZ
For overland truck food prep, maximizing the efficiency of our electric energy use for cooking a meal can be important. This is a method I've been experimenting with to efficiently boil water, then use it for hot drinks, heating precooked vacuum sealed meals "sous vide" style in a 1 gallon cooler, then using the insulated hot water later for dish cleanup and hygiene. I noticed that for camp meals, I ALWAYS want some hot drink, I always want some hot food, and I almost always heat some water later for cleanup--I realized all these can be combined to one efficient process using sous vide and a small cooler.
Many folks are wanting to use batteries to power their cooking now, but ot can be a huge watt-hour drain if not done efficiently. Even if you are using a propane burner or Coleman gas burner, it's good to save fuel. This works just as well boiling water with fuels.
Here is an example, testing some meals tonight. I have salmon with green beans; sliced roast pork with carrots and green beans in butter; and chucken bulgogi. I make these and vacpak individual meals.
Now, boil 1.5L in my electric kettle, 120watt hrs, wh. This is the #1 most efficient way to heat water with electricity, 100% of energy goes into water heat.
What do I get for 120 wh?
1.Made 400ml tea
2. poured 1100ml or grams over pouches in thermos. Salmon was packed raw, cooked in 2 min visibly, others were cooked so just reheating.
3. Water stabilized at 140f with meals, stayed > 130f an hour later for cleaning.
4. Very easy to eat out of bag cut open, so no cleanup was required, but bowls or plates would have been easy.
The energy numbers: 2 meals were 675 g, frozen but thawing in fridge, so just like you'd have in fridge camping, say 32f. Hot to eat in 10 min.
Calcs though:
1100g h2o at 212f = 233,200
675g food at 32f = 21,600
254,800÷ 1775g total = 144f
So all equalize at 144f, plenty hot and cooked.
P.s. USFDA meat pathogen lethality tables, 144f for 5 min is all that is required for complete pathogen lethality and cooking of meat. So this would work easy for raw meat sliced thin. In this case, I poured boiling water over raw bagged salmon first, easily cooking it, then added the 2nd precooked meal to warm. I just wanted to test the sous vide cooking ability, and 1100g or ml boiling water can work for 2 meals. In future, I will have all meal content precooked.
20231219_203512.jpg20231219_203528.jpg20231219_203616.jpg20231219_205402.jpg20231219_211348.jpg
workerdrone
Part time fulltimer
Great idea and I love sous vide cooking at home. I mostly do beef, pork, chicken and then sear for a final minute or so per side in a smoking hot steel or cast iron pan. Done to perfection and so so moist inside, even the pork and chicken. No need to rest the cuts either, eat immediately.
Also had to get used to the idea that still-pink chicken and pink pork is perfectly safe and done.
But - I tend to do beef for at least an hour or two at 129 degrees, chicken at 146 for usually at least two hours, pork 135 for a couple hours. These are typically thick cuts and pieces of meat, but since the cooking temps are so low I want to make very sure that the very center of the cuts spends a good amount of time at a safe temperature, since you can't easily overcook them I just want to be safe.
You did say you're using thin cuts.
NatersXJ6
You might do even better to do an actual sous vide immersion circulator. I use one at home fairly often, low cost, small to store, easy to use. I haven’t measured its power draw, because in the kitchen it isn’t really a concern.
Overall this is a cool idea though.
workerdrone
Part time fulltimer
I dedicated a big pot to it at home and made an insulation jacket for it. Bet it uses very little energy since temps are low and it's insulated. There is the circulator that runs constantly though
Dave in AZ
While camping, at least on 5 day trips or so where you have fridge space for it, the intent here to save energy use is to have PRECOOKED meals, so you are just warming them up. You could actually cook SV, but not as much savings... and its not like you're resupplying fresh meat on a trip and somehow packaging meals in vacuum bags without cooking it. So, when packaging the meals at home, might as well cook? Reheating in the water will not cook it anymore if you get the temp right, as I showed/calculated above. You could just use ziplocks I guess. What do you think of this reasoning?
I tried the SV wand itself. It is not too bad from efficiency, better than induction or microwave. However, not as good as just single water heat in a kettle then into a cooler. The motor to circulate the water uses a bit more energy, and the continued heating of the water to maintain temp uses energy. You'd have to use a really well insulated vessel to reduce heat loss. I have a link to a 1gal widemouth double wall metal cooler too, might be good? I will test more and post numbers, thanks!
See above. I love the SV, but this single boil the into a cooler is intended to give same reheating results, for less energy and gear. Due to the requirement for vac sealed food, I feel most meals will be prepped at home, so can this be precooked and only need reheating.
Yes, I have had decent results using ziplock bags with a good seal, and that could work with a full SV wand and trail cook. But most meats I like to reverse sear after SV, which lends itself to just cooking it in pan.
Anyways, these are some good ideas, and Sous Vide is very energy efficient, so I'm sure there is more overland camping technique to be discovered here!
Thanks for all the replies!
Dave in AZ
After researching electric kettles for hours, bought a 1.5L Cosori with double wall stainless. So that means no seams inside to leak, and insulated to hold heat. Love it, high quality, nothing to break. Just tested it, 93wh to boil 1 L water from 72f, exactly correct amount, 100% efficient. Used 6% of my 1536wh power station, from 82% to 76%. So far I am impressed with the Cosori, but especially the no seams solid interior so impossible to leak. Had water in it since 25th, no stains or rust.20240103_131630.jpg
AndyEdw
I’ve played around with similar setups using a thermos and vacuum-sealed meals, but I like the idea of incorporating raw proteins too, as long as the temps hold steady.
One thing I’ve found helpful is packing in some natural food options that don’t need much heat at all—things like nuts, dried fruits, and simple whole foods that can round out a meal without using up extra fuel or power. Also cuts down on the number of hot meals needed, which helps when stretching out energy use.
Herbie
Rendezvous Conspirator
Not sure how I missed this post back when it was new, but I'm glad it's been bumped up. I use an immersion circulator all the time at home, but this is an excellent reminder that (like many of us), my first experiments in sous vide were down to just using a cooler and mixing the right quantities of boiling and tap water to get the perfect ribeye temperature. A decent cooler or insulated vessel will definitely hold the temps high enough for cooking - when I was doing steaks this way, I'd mix my tap & boiling water to get 137 degree water and it would only drop to about 132 after adding the (room temp) steak and idling for 2 hours.
And I concur that using the immersion water for dishwashing, etc. is a top move.
dstefan
Two questions on this:
1) I assume there’s no such think as an effecient 12v kettle? At least I can’t find one that seems any good with a cursory search. Is that pretty much right?
2) Is anybody concerned with the safety of cooking/heating food in plastic? I searched on this, and there’s a lot of websites saying it’s OK, but seems I’d be relying on the manufacturer’s claims and we know how honest they are! Plus, the Hamilton Beach seal-a-meal bags we use are made in China. I don’t worry about putting cold food in for freezing and reheating out of the bag, but plastics release pthalates, PFAS and other plasticizers with heat applied . . .
Any good info on this that anyone has found?
Dave in AZ
Don't waste time on 12v kettle. Get a 120v for sure. Very efficient and fast.
I buy quality vac bags, and assume they are ok. Every item and piece of meat I buy at store is packaged in bags. If it needs to change, I'm not gonna be the guy spearheading that with my few times a month camping meals... this is just displaced priorities and illogical thought, IMO.
ITTOG
Well, I wouldn't call any kettle efficient regardless of power source. But yes, a 120v kettle is faster than 12v in my experience. Electric is not an efficient method for heating.
As a chemical engineer that worked in two different plastic producing plants I would say no, there is always things that leach out; sometimes from the plastic and sometimes from the additives to prevent leaching. Some more harmful than others. With that said, I use plastic all the time. Either way, we are all going to die at some point. To me, the bigger issue is the fact anyone would do that. Red meat should only be cooked with charcoal. For the entire cooking time, not just part of it. Sous Vide's and propane are sacrilegious. :LOL: :LOL: :LOL:
Kingsize24
But, but, but.....
Houie
