Hi Jeremie,...
As I plan the build & decide which bed (Bowen's or Custom Flat Bed with Boxes that sits minimum 2-3 inches higher), I was wondering if some other Ford SuperDuty + Supertramp LT combo owners with either stock box or other bed solutions could chime in on the total height of their builds from ground to top of camper.
@DADVNTRS
Check out this post.
https://forum.expeditionportal.com/...up-slide-in-pickup-camper.239844/post-3118025
Overall camper height, including vents, is 70" (5' 10"). A rooftop Dometic A/C will be taller yet.
Typical unladen, non-Tremor Superduty I think is around 37" tailgate height. Stock suspension will settle a couple inches with camper loaded. Superduty pickups have tall cabs so STC uses a 2" foam under camper on Superduty, so call foam height and suspension squat a wash.
37" + 70" = 107" (8' 11") before A/C, flatbed increase, suspension and tires increase. I think that height is about what our stock F250 and non-A/C LT ended up.
STC's estimate of 9' 5" sounds about right as most of their customers likely do 3" lift and taller tires or do an A/C. And it's probably taller if they do both.
