2002 E350 7.3L Powerstroke 102K Miles
bahlers
Up for sale is our 2002 Ford E350 with the 7.3L Powerstroke with only 102K miles. I am the 3rd owner and it has been well maintained by me. We bought it with dreams to redo the interior and build it into a true conversion van that we could spend long weeks in. Now that we have kids we don't have the time. The interior is ready to be built out however you would like.
Here is what has been done:
-6" lift U-Joint Offroad 4WD conversion
-ARB Air Lockers Front and Rear
-4.30 Gearing
-ARB on board air compressor with air chucks front and rear
-Front bumper by U-Joint Offroad
-Smittybuilt X2O 12,000 lb winch
-Rigid Spot, Driving, and Fog lights in the front bumper controlled through S-Pod
-Rear air bags for leveling with dual control
-Fox 2.0 all the way around
-DP tuner
-4" Diamond Eye Exhaust
-Aluminess rear tire Carrier
-N Fab Nerf Bars
-ARB Awning mounted with Sportsmobile mounts for clean install
-Kenwood Stereo with backup camera
-On 35" Toyo A/T 2s on XD Addict wheels
-SSBC 8 Piston Calipers and SSBC Slotted Rotors
-2 New X2 Power deep cycle batteries
-Powermaster Ultra Duty Diesel Starter (Installed fall 2024)
-New vacuum pump from Prosource Diesel (Installed fall 2024)
-New Bosch alternator (Installed fall 2024)
-New windshield (Installed spring 2025)
I also have the original invoice from U-Joint offroad detailing everything they did back in 2017.
This van can go pretty much anywhere you want to take it. It drives extremely well on the freeway as well as being easy to drive around town. It's also a one ton with a 10k lb towing capacity, so if you need to use it as a work horse and not an adventure rig you can. Asking $25,000 OBO. The van is in Montana for pickup or you can arrange it to be shipped.
janders
We had an F250 with that same engine. 100k miles is really low for a 7.3L Power Stroke. I miss that engine, it was the last of the simple, reliable diesels that just run forever.
bahlers
The underside of the body was sprayed with an undercoating. The rear driveshaft has all 3 new ujoints.
bahlers
Here is the maintenance log I kept of everything I did to it. Also, is the original invoice from U-Joint.
  • Van Invoice From U-Joint.pdf
abctrash
