Eric.Green
***SOLD*** 2021 Toyota Tacoma TRD Off-Road DCSB – $59,995
Located in Portland, Oregon
79,600 miles (daily driven, may go up)
Selling my 2021 Toyota Tacoma TRD Off-Road in Cement Grey (currently vinyl wrapped red) with 79,600 well-maintained miles. This truck has been purpose-built for overland travel, with top-tier components and professional installs throughout. I wasn’t planning to sell this truck — I was simply making sure it was solid. What changed was the blessing of our twin babies on the way, and because of that, we want more space.
Upon purchase of the truck, I put the seat covers on within a month and did the first wrap within a month as well. Because of this, the interior and exterior are well maintained. The only noticeable wear marks are on the metal bumpers and sliders (steps). This truck has been used for adventure but cared for with longevity in mind. We have taken the truck to many beautiful places. Most recently we spent 16 days on the road, going to Canada to explore Banff National Park, then dropped down to Montana to spend a week on the riverbed.
I’ve recently spent the last six to eight months going through wear items and replacing them as preventative maintenance. This has included:
I follow Toyota’s recommended intervals for oil and drivetrain maintenance, with the following exceptions:
Standard Features:
Powertrain & Capability
• 3.5L V6 engine with 278 hp
• 6-speed automatic transmission
• Factory electronic locking rear differential
• Multi-Terrain Select and Crawl Control (CRAWL)
• Hill Start Assist Control (HAC)
Exterior
• Power sliding rear window with privacy glass
• Black fender flares
• Fiber-reinforced composite truck bed with 120V/400W outlet (currently installed, but not in use)
Interior & Comfort
• Fabric-trimmed seats with 10-way power-adjustable driver’s seat (w/ lumbar) (seat covers added 1st month of ownership)
• Dual-zone automatic climate control
• Leather-wrapped steering wheel and shift knob
• Comes with factory 60/40 split rear seat with under-seat storage, current Goose Gear seat delete installed
• Keyless entry (Smart Key system w/ push-button start on Premium packages) (Two-Keys)
Tech & Infotainment
• 8” touchscreen display
• Apple CarPlay, Android Auto, and Amazon Alexa compatibility
• Bluetooth hands-free calling & audio streaming
Aftermarket Modifications List:
ENGINE
INTERIOR
Clean title, 1 owner
*More photos In comments, 10 max per page
*Contact via Expedition Portal DM
- Upper control arm (SPC) ball joint replacement with new enclosed ball joints
- Both front CV axles
- Both front wheel bearings
- Lower control arms and all bushings
- Inner and outer tire rods
- Rear differential rebuilt by for preventative maintenance
- AMSOIL 0W-20 oil
- Front and rear differential oil changes more frequently (every 30k)
- Transmission serviced at ~45k by Toyota
Standard Features:
Exterior
Interior & Comfort
Tech & Infotainment
ENGINE
- Factory Engine components
- Overland Tailored Tune (OTT) - With custom mapping for improved shift points, customized throttle response (smoother for trials), ECT remap for "dual map function", AGM battery support for higher charging voltage [This tune is amazing, I highly recommend it for any Tacoma. The point is not for power, it is for improved driving experience]
- Full vinyl wrap (red) – installed June 2024; truck has been wrapped since purchase (door decal under mirrors can be removed)
- Alu-Cab ModCap camper, professionally installed by Mule Expedition Outfitters with extra seal process
- ARB Snorkel
- CBI Offroad: Adventure Series aluminum front bumper, high-clearance rear bumper, rock sliders, full aluminum skid plates (engine, trans, gas tank)
- DRT Offroad rear diff skid
- Warn VR 12K winch
- Prinsu Pro roof rack with handles and area lighting
- 18% ceramic tint all around, 50% on windshield, 5% banner
- Window rain guards
INTERIOR
- Factory black interior, including headliner
- Clazzio seat covers since new (driver’s side shows wear)
- Goose Gear full rear seat delete
- MOLLE headrest rack by MESO Customs
- Matching interior door decals by Taco Vinyl
- Wired for Dometic fridge with Dometic wiring harness (Dometic CFX 55 not included)
- Expedition Essentials 3TPAM dash mount, will include Mic mount.
- All-weather floor mats
- Kenwood 8” subwoofer
- MESO Customs red/white interior LED lighting
- Peak Suspension 3” lift (2.5” DCS coilovers w/remote reservoirs) (Installed November of 2023)
- SPC upper control arms (latest bushings installed September 2024)
- East Coast Gear Supply (ECGS) Clamshell bushing (eliminates needle bearing) - Installed <20k miles for preventative measures
- Hellwig upgraded sway bar
- Total Chaos spindle gussets
- Marlin Crawler cam tab reinforcement
- DRT cab mount chop
- DRT rear hanger upgrade with crossbar
- Ironman 4x4 constant load rear leaf pack
- Sumo Spring bump stops
- 295/70R17 General Grabber X3 tires (matching full-size spare on swing-out)
- 17” Method 704 wheels – matte black
- Power Brake X-Line big brake kit (red)
- Forum LED projector headlights & tail lights
- PowerTrays engine bay system
- SwitchPros 8-switch panel
- Baja Designs: S2 reverse lights, 4 red area lights on roof rack
- Interior red/white LED lighting
- (7 LP4 Rack mounted lights not included, found water intrusion and will be warranting them. I will be including the mount for the rack, and a faring that has no cut out for a clean look).
- Premium dust/water-tight install by Mule Expedition Outfitters in June of 2024
- Full Viato drawer/cabinet system
- 100Ah lithium battery from Antigravity
- Redarc BCDC25 (solar-ready) on roof and portable panels
- Diesel heater w/external 5-gal tank
- GP Factor power/USB panel
- GP Factor rear door MOLLE panels
- 13-gal Alu-Cab water tank
- 813 MOLLE panel mounting over water tank
- Alu-Cab shower room
- Alu-Cab 270 awning
- Alu-Cab aluminum table 813 interior mount
- Alu-Cab Side/rear bug nets
- upgraded bed struts & reinforced mounts (for more weight capacity)
- Alu-Cab crossbars for rooftop gear
- Freedom Locker mod – use factory locker anytime (2WD, etc.)
- ARB Twin Compressor + 1 gal tank (under hood) w/ Mountain engineering Off-road mount
- Wavian 5-gal diesel Jerry Can w/ no drip quick disconnect
- Wavian 5-gal gas Jerry Can
- Comes with factory rear seats & OEM tailgate (wrapped)
- Factory tailgate, wrapped to match truck.
- Kenwood Dual Channel HAM radio with external mount antenna
