2009 tundra - scheel mann conversion
Slamd58
I have Scheel man seats in my 2006 Lexus LX470 and have an airbag proxy to make the Lexus think everything is ok. I have both drivers side and passenger side seats. The passenger sensor in the seat was taken out of the old seat and is still plugged in. The sensor is pretty basic and we have pressure on the sensor so it thinks there is always a passenger in the seat. I occasionally get an airbag light on and once I wiggle the proxy under the seat for better contact the airbag light goes off. I believe tolerance stack sells the airbag proxy depending on the type of connector you have. Definitely some of the most comfortable seats I have ever ridden in~~
We hear about this every now and again. When folks use just the resistor alone, the connection can fail. The airbag connector uses flat pin terminals whereas the resistor's leads are round. There is contact on only two points of the resistor so not ideal. But by not using the correct flat terminal pins it also means that you don't "activate" the secondary part of the SRS connector which has a built in fail safe. Our airbag proxy uses the correct OEM pin terminals which engage the SRS connector in both stages.
seahaul
Btw. The Geordanos on desk to glory and are currently travelling across the pond in Europe have a gen 2 Canadian Tundra with Scheel Mann seats. I think they have a write up on thier web page, or at least somewhere, about the conversion. https://www.desktoglory.com/
darrylkd
