1996 montero ls 4h issue
commostud
Good Evening,
My 1996 Montero LS 3.0 with 162k has an issue with the 4wd system. The issue is when I put it into 4h it feels like something is slipping. The rpm's will go up but the speed barely increases. When I put it into 4HL it stops the slipping issue and we move right along. 4L works as well. The tranny does not slip in 2wd.
I will be changing the 4wd vacuum solenoid next payday but don't think that effects the slipping issue, I could be wrong.
What could cause the slipping in 4H and not anywhere else?
Thanks
project13support
