Fuel Tanks and Jerry Cans relating to Fuel Range
Gravelette
If you can be a little patient I will be glad to share the information. Once I have the tank here and installed I will be doing an entire write-up on it. Just be aware that it will require a new fuel pump assembly and possibly a fuel filler neck and will be costing in the range of $2500-$3000 USD.
Any reason to not go ahead and share the source?
Jupiter58
If you are planning a trans Taiga trip, take extra fuel. You have 1 fuel stop and that’s it. My ram 1500 with a 33 gallon tank pulling a Patriot Campers X3 needed 15 extra gallons to do both the north and south ends of the Trans Taiga. Take the extra fuel. If you need it you have it. If you don’t need it, you have it to fill up back at home. But you have it, when you may need it.
So how many miles did you do, distance between gas stops and your mpg?
Datsun Man2
Perhaps things need to be verified on what all needs to be done? Perhaps I don't want certain individuals from a certain forum to know yet since all they do is talk **********? I'm already doing the foot work as we speak and once things are confirmed, thing will probably move forward for other, but others justifying the cost will be the issue especially with the lover Cheeto inspired tariffs in place.
V45W_Proto2.5
