Do You Know Where The Emergency Door Release Handle Is Located On Your Cybertruck?
AbleGuy
Officious Intermeddler
This would info below be good to know if you ever had a crash:
“When power to the truck’s electric doors was shuttered by the fire, the passengers were locked inside with no way out.”
(It’s alleged that the driver and two passengers were trapped amid flames and smoke that eventually killed them.)
The lawsuit being reported in this article alleges:
“Tesla door handles have been at the center of several other crash lawsuits because the battery powering the unlocking mechanism can be destroyed in a fire and the manual releases that override that system are difficult to find.
“The backup mechanical release for that door was concealed beneath the liner of the map pocket at the bottom of the door – hidden, unlabeled, and impractical to locate or use in the smoke and chaos of a post-crash fire,” said the Nelsons. “As a result, the Cybertruck’s design left … (the) occupants with no practical way to escape.”
😳 That sounds pretty gruesome!
So if you’re a Cybertruck owner it’d obviously seem to be good practice to make sure you know exactly where these emergency releases are and maybe even practice implementing them.
For more, read:
ThundahBeagle
Ok, why in the world would the alphabet soup agency (NHTSA) even ALLOW this type os design flaw, in the name of "elegance"!? Sheer stupidity, and they should be being used as well. I have a frigging whole warning about airbags on my sun visor and theres nothing I have to go fidget around and find in order to operate them -just a little bad luck
ThundahBeagle
At least on the mod 3 of a few years ago, the door release lever is pretty obvious.
My Sweetie has one, that for the longest time I used the lever because I was unaware of a button release.
(As @Verkstad cycles through M, 1, 2 , 3. 4, 5, and 6 on a 10 year old GMC column shifter for the auto transmission) ha ha, I love it, though. Common sense prevailed and you were the hero! That's absolutely something I would do. In the Tesla, not in the GMC.
cricketwagon
Horror! Outrage! Okay... what do you do if the door mechanically jammed on impact ? Which emergency lever you got to pull ?
85_Ranger4x4
This is good to know in case a person would come across someone trying to get out of one.
Henrybrowne
