1996 5 Speed Land Rover Discovery 1.0
sinuhexavier
1996 5 Speed Alpine White SD (No Sunroofs or power seats)
$3,746.78
147k miles +/-
$500:::ARB winch bar spring 2006
$500:::Warn 9.0 Winch synth line and EE shackle mounts spring 2007
$200:::2 IPF 900XS Lights factory wired spring 2006
$200:::Olivares Steering Components spring 2007
$450:::Olivares sliders spring 2007
$75:::Olivares Spring retainers Spring 2008
$50:::Stainless steel brake lines spring 2007
$100:::OME HD Shocks spring 2008
$200:::OME HD Springs spring 2008
$50:::Rubber Spring Isolators all the way around spring 2008
$50 :::EE Rear Shock Mounts spring 2008
$200 (ea)Tom Woods Drive shafts front and rear spring 2008
$250:::RTE Rear Links Spring 2008
New Leather on front seats Fall 2007
New Clutch spring 2007
Alpine CD player with Alpine amp and polk audio speakers spring 2006
AUX 12v (2) plug power in the back
Truck runs great, transmission is strong, leaks from oil pan, rear main seal, and oil cooler lines.
It needs a new battery, steering box, and cam shaft position sensor, it will also need tires in 20k. Would drive across country after addressing the camshaft position sensor and battery without hesitation. Here is the last big trip I did, 7 days of which were solo with hundreds of miles off road. 1.0 never left me stranded or even came close... Well there was that lame rotoflex issue once, but that was it.
Both rear quarter panels are crushed you can see in photo and hood is dinged ever so slightly on the passenger side all the way in front you can see it in the photo. The paint is in immaculate condition.
Minor rust in usual places, door jams and alpine windows...
***THERE IS NO RACK AND NO REAR DOOR TABLE***
Not going to part it out, unless I don't sell it until Mid-FEb, although I have priced out what I would part it out for if that time comes...
Plesae direct all questions to sinuhe@greendotfilms.com, I am in the midst of a big project and am not hitting boards all that often.
Tree
WOW!!!... that first pic is just.....beautiful!!!!! :wings: Where is that!!??!!:smiley_drive:
haven
"It needs a new battery, steering box, and cam shaft position sensor..."
Let's budget $150 for the new battery. Can anyone hazard a guess as to the cost of the steering box and cam shaft sensor replacement, if the work is done by a professional mechanic? How about the cost to slow down the oil leaks?
Chip Haven
sinuhexavier
Sorry Truck is located in Los Angeles, CA...
Sure use the image on the home page...
I have moved onto a 1999 White Discovery 1, there is a thread about it somewhere, so I haven't driven this truck since August.
I'd say a safe bet on getting the truck absolutely rocking is $1,000 in mechanics and parts on the high end... And I was going to put the $800 Rovertym bumper before I bought 2.0, which would have covered the crushed rear quarters as well as being the best rear bumper on the market.
Anyone that has seen this truck can attest to how clean it is... Interior photos could be tough as I am in the middle of a big project and won't hav etime until the 24th as I will be traveling.
Thanks!
Look forward to your new build
I would absolutely like to second the exquisite nature of your photos and appreciate you leaving access for us all on your flickr stream. Your pictures are incredibly vivid and they embody every aspect of the landscape. I also appreciate your philosophy when it comes to artifacts; discovery of cultural or historical gems can be appreciated without having to take it with you
iStan814
