Trailer Sliding Platform
socaljeeper
I am thinking about fabricating a sliding platform on the bottom of my M-416. I am looking into different heavy duty drawer slides and I am finding out they are on the expensive side. They range between $200-$300 a pair for the 48" slide. Does anyone have a cheaper alternative or know where I can get a good deal on slides? Here is a link to rockler where I found a heavy duty 48" accuride drawer slide:
http://www.rockler.com/product.cfm?page=1491&filter=48%22%20drawer%20slide
Tumbleweed
Would some Delrin type rollers on 1/2" roundstock, a few stops and guides work? Just thinking outloud and trying to give you an idea.
elmo_4_vt
I bought some 36" slides with, I think, a 200+ pound rating from wood workers wharehouse for around $90.
Here is a link to ones like I bought, although it looks like their price has gone up a little:
WoodWorker's Wharehouse
Don
R_Lefebvre
That's what I'm been thinking of doing. Some aluminum extrusions, and teflon blocks might do the trick. Might be a little harder to slide, but probably cheaper.
davegonz
That or bearings on some 1/2" shoulder bolts. Look at how the Engle fridge slide is built.
Take a look at this build: http://www.expeditionportal.com/forum/showthread.php?p=237671
Just scale it up.
Stouttrout
I made my own once for a Ramcharger I used as an office. It had all the computers and printer in it and a desk that slid out. It was similar to the above pic for the fridge slide. I bought Bearings from ACE Hardware and used angle iron to mount it to. I think I spent about $25 bucks on it and it would hold alot of weight.
ntsqd
Heretic Car Camper
My first thought was for these:
page 1098 on mcmaster.com
The least expensive sealed option there are $14 each and has these load capacities:
Max Static Load: 2065 lbs.
Max Dynamic Load: 1660 lbs.
That's per bearing!
An issue that an under trailer slide is going to have is the build-up of dust and muck. I would suggest using the outside corner of a piece of angle for the rollers to roll on, rather than rolling them on the flat. On the flat provides a ledge for the dust & muck to build up on, and then the roller won't want to roll.
The Adam Blaster
I always thought that for a trailer, a large slide-out drawer would be a great way to easily access everything in the trailer all through the rear tailgate.
Those units that ntsqd would be great for that purpose.
elcoyote
Supporting Sponsor, Overland Certified OC0004
Make sure you have a rear stabilizer or that the trailer is coupled to the vehicle so that when you shift the cargo weight on the slide rearwards you don't pop a dangerous wheelie with the front of your trailer.
The Adam Blaster
Good tip - something I would have made the mistake of before putting stabilizers down! :oops:
Granted, if the trailer is still hitched to the tow vehicle, you wouldn't have to worry.
R_Lefebvre
I love "trailer surfing" on my utility trailer while unloading it... :Wow1:
OlympiaFJ60
When i built my rear draw on my FJ60 I used the slides from joeybed.com. They are rated upto 500#. I have been thinking of putting one in the trailer too. You have to email them at joeybed but I found some prices here http://www.truckcargobed.com/joeybed/full_ex.html. The thing I liked about the Joey Bed slides is that they lock at full closed, full open and partial open with an easy to us unlocking leaver.
socaljeeper
Thanks for all the ideas. I think the Mcmaster bearing rollers will work the best and the price is not too high. I am still thinking on how I want to design the tray and how the rollers would work the best. Those Joey Bed slides are really nice. My brother was telling me that his entire fire engine is outfitted with those type of slides. I will post up some pictures of when I get started. Keep the ideas coming! :)
Houie
