Built II Beat Fab. Taco for sale -
TBob
Sold -
03 Toyota Tacoma TRD SR5 TRD 4x4, V6, 5 speed - Original owner! 62k, this truck is loaded!! One that drives excellent on road and can still handle hard core trail use. Dual transfer case with Inchworms 5.1to1 crawler. New Truxxs MT's 33" tires, Donahoe adjustable coils up front with custom 63" chevy leafs out back with 12" travel 5125 Billstien shocks. New TRD Clutch. All Amsoil full synthetic oils used. Tons of extra's, all fabrication done by Built II Beat Fabrication.
Factory rear Electric locker
Front locker is a lock right
Front tube bumper with winch mount – BIIB Fabrications
Warn M8000 winch
Rear tube bumper w/ 2” receiver & 7 & 4 plug connection towing capable - BIIB Fabrications
http://s98.photobucket.com/albums/l251/aztbob/rear bumper/
Draw-tite II brake controller
Rear bumper swing-out rear tire carrier / license plate holder – BIIB Fabrications
http://s98.photobucket.com/albums/l251/aztbob/swing out/
Amsoil dual bypass filtration system (8.5 quart oil capacity) http://www.4x4wire.com/toyota/tech/amsoil_bypass_filter/
Optima Deep cycle Blue top – D34M
Volvo S60 leather seats – drivers side power
Garmin V GPS
Deck plate mod http://www.yotatech.com/f130/deckplate-mod-75169/
2” Body lift – 2" pucks grade 8 bolts.
Lift Lips http://www.liftlips.com/
B&M quick shifter
Marlin heavy duty shifter seats
Shifter extensions – custom made
Dakota digital (re-calibrates speedo) http://www.dakotadigital.com/
Rock sliders – BIIB Fabrications
Turn signal re-locate
http://www.4x4wire.com/toyota/tech/tacoma_turn_signal/
Rear shock re-locate – BIIB Fabrications
12” travel 5125 Bilsteins
4” Extended rear brake line
Donahoe Adjustable coils
Lower ball joint bolts swapped out with grade 8 bolts.
Polly steering rack bushings
Single cab cup holder – adds 2 addition cup holders
Cobra 75wxst
Wilson 1000 antenna – hard mounted
External CB speaker mounted in headliner
Rock lights - 5 55w Halogens
Reverse light – 2 55w Halogens
Rear diff breather re-locate
MV50 portable air compressor
Steering pump cooler – Moroso 41200 from sumitt
Windshield Washer reservoir relocated & custom made - http://s98.photobucket.com/albums/l251/aztbob/water resivior/
Front cab body mount redone for high clearance
Inchworm 5.1:1 crawler - http://www.inchwormgear.com/index.php
Custom built shift linkage to run 3 sticks in the proper location - BIIB Fabrications
http://s98.photobucket.com/albums/l251/aztbob/tripple shifters/
http://ttora.com/forum/showthread.php?t=38756&highlight=shifter
Transfer case shift rails split to allow all gear ranges to be used in 2 or 4 wheel drive.
Custom built crawler skid plate - BIIB Fabrications
Front Range Off Road cross-member & skid plate(modified)
Pinion E-brake
Summit Proportioning valve Kit for adjustment of rear brakes.
Rear differential guard – custom made
2 layers of Fatmat on the floor and one on back of the cab.
Demello frame re-enforcement plates
Rear frame boxed - BIIB Fabrications
Rear suspension -
63” Chevy spring install frenched into frame.
http://www.tacomaterritory.com/forum/showthread.php?t=67219&highlight=frenched
2” adjustable Rubicon Flex joints mounted to frame for top shackle mount.
½” Top plates, flipped u-bolts 3/8” Shackles at 5.5” eye to eye. 3” tall x 4” x 2.5” Polly bump stops - All BIIB Fabrications
Diamond plate Bed tool box
2 New lifetime warranty Napa 1/2 shafts and one spare
Electrical –
Grey wire mod (use of rear locker in 2 wheel drive)
Free Factory alarm upgrade http://www.customtacos.com/tech/index.php?article=12Seat belt buzzer disconnect
Door chime disconnect
Turn signal re-locate to running lamp http://www.4x4wire.com/toyota/tech/tacoma_turn_signal/
Factory fog switch for rock lights, w/ 30 amp relay http://www.4x4wire.com/toyota/4Runner/tech/switch/
This amber factory switch is #00550-35976
Factory fog switch wired for PIAA lights, w/ 30 amp relay
Full time power outlet
In cab winch control switches on drivers door panel.
Fuel pump kill switch - 70205K26 & 7172K221 - McMaster-Carr
DTRL disconnected.
ADD in cab switch added (2 low mod)
Truck is white with tan interior
Original AZ truck - zero rust.
$16500 OBO
480-209-7039
StumpXJ
SE Expedition Society
That is a killer set-up on the Taco. Man do I miss mine....
Good luck with the sale.
~James
