Engel 35/45 Hinge Lock (35HLK)
Has anyone ever used one of these?
I have an ARB fridge that I want to lock the hinge on.
Does anyone have instructions or a picture of it installed?
Any opinions on it?
Thanks,
Nathan
Martyn
Nathan, we have the kit if you want to do the install.
cshontz
Supporting Sponsor
I use a hinge lock, Nathan. Little plastic tab functions as advertised. Not much else to say. I'm happy with it. :)
teotwaki
Excelsior!
Definitely a must have as the loose fit of the hinge pins on the fridge's lid allow the lid to move a bit and then the lid can fall off if your vehicle is off level to the right. Drove me nuts!
Dave
Must have is right. For what these fridges cost, they should come from the factory with a lid that stays on.
Dave Bennett
Adventurist
They should come with the latch standard. It is nice in some cases to be able to remove the lid easily.
SMD
My lid slips off occasionally even with the hinge lock. Not as much as pre-lock, but every now and then.
Thanks for the replies every one.
The lock looks like the plastic mold is made to split. Where does the other piece go?
I presume on the other hinge is that right?
Nathan
Dave
Nathan
Yes, the blank piece goes on the other hinge to act as a spacer.
Green Ganesha
Had the same problem myself, especially with the extra weight of a Two Zone, so doubled up and installed a a second lock, on the right hinge.
flipstick
