Project XXX
craig
Any chance I could talk you into measuring the length and width of the pod portion of the daystar switch panel? I'm considering a similar modification but want to verify that it will fit before ordering one.
Thanks for the help,
Craig
as mentioned i had problem with the ARB switch location.
they were shut off by the stick shift boot when in first or third gear...
here's my solution for the problem:
use the panel that didn't work in front of the shifter and modify it
take off the windshield cladding
and modify that, too
a few drilled holes, screwes, etc. and...
easy reachable...
XXXpedition
i hope i don't forget to measure that at night (got the truck at home - i ride my bike to work :sombrero:)
only thing i can tell you now, is that it's just a bit wider than 4 ARB switches :)
bobDog
at least for now - we'll see... :sombrero:
i did like the gray!!!
Ya know it was just as easy painting it gray as it was black :coffeedrink: only now you have to take it apart, scuff it and paint it again later (gray). The more black you got the more dirt you see!
Zeero
Black is better!
Gray makes it look half finished, and Navy ship-like.
Black wins! :victory::wings:
:sombrero:
XXXpedition
hey craig,
sorry it took me some time...
so, the switch panel center is just a bit wider than 4 ABB switches:
that's exactly 11cm or 4.33"
and the depth is 5 cm or 2 "
hope that helps!
sven
bobDog
Sven, wondering if when the roof is off and the lights are on if the glare on the front windshield will be bothersome? Or have you already tried that out in Morocco? :coffee:
XXXpedition
and here is the final pic of the roofrack!!!:victory:
the second spare tire is still missing, though, but i bet you can figure out where it goes :)))
Houie
