Mars Rover Needs A Winch
James86004
Too bad its warranty period expired 1800 days ago. NASA keeps extending the mission, but it looks pretty stuck. It has had one wheel stuck for a couple of years now, so it has to drive backwards and drag the wheel.
grahamfitter
How about pushing on the ground with the camera robot arm to lift the vehicle up so it can drive off?
Cheers,
Graham
Brian McVickers
Administrator
Staff member
On the next one they should mount a little tiny Pull-Pal on the end of a cable. When stuck it could shoot out the anchor and then winch itself off!
Or some sort of (emergency use only) ride height adjustment system.
mmccurdy
For less than $100, they could've equipped it with a Hi-Lift jack! Stoopid rocket scientists!
Hrm... so that's $100 for the cost of the jack, then (assuming 14kg of mass) about half a million bucks to get it to Mars... that's assuming you're still getting a ride on a Delta II, and if that's the case, what instruments will you be getting rid of? IIRC the entire Pancam Mast Assembly weighed in at around 9kg...
j/k of course, but when you're talking about launching stuff hundreds of millions of miles away, things get complicated pretty quickly...
I spent about 48 hours last weekend winching my way through the second 10 miles of the Rubicon in 2WD, and I actually worked on the Mars Rover mission back in the day (I do activity planning and resource modeling software as my regular-person job), so you can bet I feel their pain and I'm pullin' for it to get "unstuck" soon :sombrero:
muddyluxury
drop a thermite gernade, mark with IR chem light and call in an Airstrike, then CM... wait we can't do that to five years of NASA's budget can we?
2drx4
They should have recruited better drivers to avoid getting in that situation. :smiley_drive:
Actually, I hope they get it unstuck. I always like to see a piece of equipment outlive it's expectations. Like both the Voyagers, they're still out there...
Antichrist
That's what they get for measuring tire dia in centimeters and obstructions in inches.
They need a Pilow Track.
lowenbrau
I guess Japan could send a MarsCruiser with a tuggum strap.
Have they tried airing down? Interco should sponsor the tires on the next mission. Those street tires look to be wearing well but are a bit underclassed in the rough stuff.
Houie
