Yaesu FT-7800R HAM Radio, With Remote Mounting kit, Dual Band Antenna
SOAZ
Tim and Kelsey get lost..
SOLD
This radio was put into my truck for about 3 months. I never mounted it so the wiring kit and all of the mounting pieces are still in their packages. I mainly use 2m so I bought a 2m only radio and this one was never used after that.
The only wear on the radio is some dust on it from being in the truck on a couple trips.
Below are some retail prices from Ham Radio Outlet so you know what you are getting. My price is below that.
6) Manufacturer: YAESU
Item : YSK-7800
Description : SEPARATION KIT FOR FT-7800
YOUR HRO PRICE $49.95
7) Manufacturer: YAESU
Item : FT-7800R
Description : ***SYSTEM STOCK ONLY NO MORE AVAIL*****2M/440 DUAL BAND FM MOBILE
$239.95
Price includes a $58.95 Dual band Antenna by Comet.
Also included is your choice of a Diamond Magnet Mount with Coax cable or a coax cable unused set up to go into whatever solid mount you want to use. The magmount or Coax would cost an additional $20-30 normally. See pictures.
For all of it: $260
The FT-7800R provides 50 Watts of power on the 144 Mhz band, and 40 Watts on the 430 MHz, and is designed for simplicity of operation along with high performance in the receiver section. The FT-7800R is ideal for the active Ham who has a need for simplex, repeater, or FM satellite operation on both bands, but without the complication of cross-band repeat capability, which is available on our FT-8800R and FT-8900R models.
NOAA Weather ALert (U.S. Version only)
A special memory bank on the FT-7800R allows instant recall of the ten NOAA Weather frequencies. What's more, you can enable a special “Severe Weather Alert” feature that will sound an alarm when a NOAA station transmits the special alert tone during a severe weather alert broadcast.
Over 1000 Memory Channels
The FT-7800R's incredible memory channel capacity includes registers for over 1000 channels, each capable of storing a 6-character Alpha-Numeric label. And the memories may be stored in any of the 20 available memory groups; a particular memory channel may also be stored in multiple groups, if desired.
WiRES™ Internet Linking Capability
The FT-7800R's DTMF signaling capability includes provision for easy access to Yaesu's WiRES™ (Wide-coverage Internet Repeater Enhancement System) Internet linking nodes, as well as other linking systems that require a DTMF string for access.
YSK-7800 Remote Mounting Kit (option)
Using the optional YSK-7800 Separation Kit, which contains both cabling and a bracket for the remote front panel, you can mount the FT-7800R's front panel on the vehicle's dash board, then stow the radio's body under the seat or in some other convenient, out-of-the-way location. The cables are approximately 20 feet (6 m) in length.
One-Touch "Hyper Memory" Operation
Five front panel keys allow complete transceiver configuration status to be stored for convenient one-touch recall. So you can set up favorite frequencies in each operating band, including the receive-only bands, then recall them with a single touch of a button!
High Power Output
Boasting a big 50 Watts of power output on 144 MHz, and 40 Watts on 430 MHz, the FT-7800R also includes provision for three lower power levels, so you never have to use more power than you really need. The power level is stored in regular and Hyper Memory registers, too
Wide Receiver Frequency Coverage
The FT-7800R provides receiver coverage from 108 to 520 MHz, and 700 to 999.99 MHz (cellular blocked), so you have available a wide range of monitoring excitement, including AM Aircraft, Public Safety, Government, Business, and, of course, Amateur communications. The synthesizer steps appropriate for the operating band are automatically selected, too!
Fergie
One of the benefits of being a stay at home Dad is that I can browse during the day while the kid is taking a nap.
Thanks Tim.
seth.c96
