texasnielsen
Outdoorsman
SOLD
Conqueror Base Camp for sale by owner as a turn key* transaction.
Illness is forcing sale (but not mental illness to cause me to give it away)
This unit is registered in Texas as a 2009 model, purchased new this past winter. An ongoing back problem has caused me to reevaluate the camping situation; honestly I wish it didn't have to come to this.
[* I am including all "standard equipment" as well as the camping products I currently have in the trailer. So things like ground covers, grille, stove, propane bottles, sleeping bags, camp chairs, 2 cots, air mattress, external 10lb propane tanks, spare Hella plugs, and frankly a lot of other stuff I am not recalling at the moment are included.]
Here are the standard features of the Conqueror Base Camp:
Body
Exterior dimensions : 12 ft long, 6 ft wide, 6 ft high.
Standard trailer box with lid and nose cone
Frame
Heavy duty welded steel
Suspension
7 Blade Leaf springs, Heavy duty Shock Absorbers.
Axle
Solid beam axles with drum brakes.
Braking System
Trailco Sigma auto reverse coupler with surge brakes.
Coupling
Sigma hydraulic overrun coupling with hand brake for parking. A standard 2" square receiver for the towing vehicle.
Access
Lid tilts up for access to main compartment. Three lockable doors (2 side and 1 rear) fitted with heavy-duty hinges. 4 wolf pack boxes in the interior.
Paint
All joints sealed with automotive body sealant. Acrylic stone chip primer. 4 coats of white Acryline automotive paint finish.
Roof Rack and Ladder
Opens to 8 x 8 ft. Closes to 4 x 8 ft x 10 inches for closed tent, storage in between, with loading rack on the top. Heavy-duty steel ladder to access tent.
Roof Rack Tent
Heavy-duty canvas tent with 4 side openings with dual zippers, windows and bug screens on 4 sides. 8 x 8 x 6.5 foot high.
Side Tent
Add-a-room side tent fitted underneath open roof rack, approximately 6 x 8 foot floor area. Heavy-duty canvas.
Foam Insulated Saddle boxes
Ridgidized aluminum cases with neoprene seals for water and dust resistance. One is fitted for Minibar, the second fitted with Power Pack.
Storage Includes four dry storage bins.
Minibar
Setup in Saddle Box with compartments for 8 bottles.
Kitchen Unit
Two ridgidized aluminum cases with neoprene seals for water and dust resistance fitted on end of trailer. Two fold out aluminum kitchen tables connecting open cases to form kitchen table of 1.5 ft x 8 ft.
Cutlery & crockery
Service for 6 includes melamine platters, bowls, mugs and kitchen utensils; glasses, full set of cutlery and steak knives. Individual compartments for all items in kitchen unit.
Cooking pots
Set of 3 nested heavy-duty stainless steel cooking pots.
Refrigerator Mounting
Sliding rail system for refrigerator cooler mounted inside on the floor of the trailer and accessible through the rear tailgate.
Power Pack
Industrial Intelligent Power Pack installed in saddle box. 20 amps, 13.8 volts. 5 circuit breakers and GFI. 110 volts AC adaptor coverts 110 volts to 12 volts to power fridge, lights, outlets or charge the battery. Meter shows the battery storage level. A heavy duty, 65 foot, extension cord to connect trailer to a 110 volt outlet or to a portable generator.
Lighting Package
Two Hella halogen spotlights; 1 mounted on front and 1 on rear of roof rack. 2 fluorescent lamps; 1 mounted inside the trailer, the other has 10 foot cord. 3 Hella Plugs; 1 on front and 1 on rear of trailer lid, 1 inside trailer.
Water Tanks
Two 20 gallon Polyethylene tanks for water mounted underneath trailer with risers and bottom mounted taps.
Shower Hose & Water Pump
15 foot hose with water pump to insert in water tank, and quick disconnect fitting on other end for shower head or spray nozzle.
Propane Tank Holders
Two holders for mounting 10 Lb Propane Tanks to side of Trailer
Jerry Cans
Two 20 liter metal Jerry cans for water or gas. Military green
Jerry Can Holders
Two holders for mounting Jerry Cans on side of trailer.
Utility Table
Metal, 2.5 x 6 feet, and mounting for under roof rack
Nose Wheel
Anti tilt leg and removable Jockey wheel, struts to assist in opening and closing lid. Wheel arch rubbers.
Other additions: The wiring harness has been upgraded to a standard round 7-way U.S. vehicle plug in. I have upgraded the safety chains, replaced #4 with #8 rated bolts, repacked bearings, and added safety chains to the two water caps (was worried I'd forget where I put one down; this way they are always connected to one another), and a safety chain to hold up the nose wheel when in transport mode.
It has been used locally and once for a extended trip to the North Carolina seashore. Always garaged and entire unit (box, canvas, etc.) are in excellent condition. This is an all-inclusive sale, I will not be selling individual components. Located in a suburb of Fort Worth, Texas
First offering made to the fine members of Expeditional Portal Forum
With the Edgestar 63q freezer - $7,500.00
Without the freezer - $7,000.00
Body
Frame
Suspension
Axle
Braking System
Coupling
Access
Paint
Roof Rack Tent
Side Tent
Minibar
Kitchen Unit
Cutlery & crockery
Cooking pots
Power Pack
Lighting Package
Water Tanks
Jerry Cans
Jerry Can Holders
Utility Table
Nose Wheel
