bajaslist - Things you can't live without
BajaTaco
Swashbuckler
The following items are for sale. Buyer pays for shipping. PM or email cmarzonie at yahoo.com
Update: Most everything has sold.
Summary of items still for sale:
  • Power Painter
  • Submerisble pump
  • Sway-A-Way coils 3/13/650
____________________________
Garvin Industries Wilderness roof rack (used), 44.5"x60.5"x6.5" comes with: Spare tire mount (lockable), Hi-Lift mount (Loc-Rac), (3) light tabs, (2) KC 100w lamps, Quick-fist mounts for shovel, etc. & (2) bike rail mounts (see photo for bike configuration) Does not include Yakima crossbars/towers shown in photos - $450 *SOLD*
PalmOne Zire 72 PDA with stylus and built-in camera. Comes with: USB 12V & 120V charger w/data cable combo, JavoEdge clear case, and 256mb SD card - $50 *SOLD*
Magellan Meridian Platinum GPS receiver w/extras **ONLY WORKS ON 12VDC EXTERNAL POWER, sold AS-IS** - $40 *SOLD*
This is a factory refurb unit that is in good physical condition except that it doesn't power up from the internal battery compartment. It does work on 12V external power though, so would be fine for in-vehicle use with a full-time 12V power source. I didn't try to fix the battery compartment issue, so maybe it can be opened up and fixed. Comes in original box with manuals and discs, as well as 12V power cable, Serial data cable, Swivel vehicle mount, Lanyard, and Mapsend Topo V3.0 software.
Kenko 0.5X wide angle lens with adapter tube for Canon A75-85 series cameras. Also fits 37mm camcorders, comes with UV filter that fits tube - $15 *SOLD*
YAKTRAX size large - $10 *SOLD*
Aluminum antenna bracket, bolts to small tubing, racks, etc. - $5 *SOLD*
Design Salt mummy liners (2 avail) Size Reg. Poly/Cotton - $12 ea. *SOLD*
Road Hazard triangles w/weighted bases, free-standing, good for windy conditions or where flares are hazardous. (2 avail) - $4 ea. *SOLD*
Walther Jungle Survival Tool, 17 1/2" overall when assembled. Tools include knife with 4 5/16" blade, shovel, pick, and sling shot. Shovel, knife and pick are constructed of stainless steel. Handle is made of textured Kraton. Black ballistic cloth sheath holds entire tool. - $15 *SOLD*
AutoHome foam mattress with zippered removable cover, approx. 70"x54"x3", fits perfectly wall-to-wall on a 98-00 Tacoma sleeping/cargo deck - $20 *SOLD*
More items to follow.
BajaTaco
Swashbuckler
Wagner Power Painter 220, airless 85w, sprays 1 gal in 15 mins. (paint jar has dried latex paint inside, will need cleaning or replacement (they cost about $8) - $35
Little Giant submersible pump, "1 Series" Model 1, 115VAC, 1.1A, 1 phase - $35
BajaTaco
Swashbuckler
Toyota Tacoma parts - from 98 Xcab V6 manual 4WD
Front differential with OEM 4.10 gears, electric actuated ADD - $125 *SOLD*
Steering rack with tie rods, good working condition. One rod end needs a boot. - $100 *SOLD*
OEM front sway bar - $20
"Thermonuclear" sway bar quick-disconnects *AS-IS* one of them needs some hardware: bushing, some washers. and wing nut. Mounting bolts (for lower a-arm) not in photo, but I have them (they're still on my truck). - $30 *SOLD*
Bosch oxygen sensor, new in box - $30 *SOLD*
O2 sensor tool kit, new - $12 *SOLD*
OEM bumper lights - $10 *SOLD*
Optima battery bracket (raises battery to OEM height) - $6 *SOLD*
Battery bracket, allows fitment of Optima Group 31 (large) battery in OEM location (cable revision/extension required) - $20 *SOLD*
OEM ashtray and cig lighter assembly, black - $10 *SOLD*
BajaTaco
Swashbuckler
(2) 10,000 lb. hooks, (1) OEM hook, fits front frame rails of 98-00 Tacoma (and likely others, it's a common item) - $8/all *SOLD*
Rexsname
Chris,
I'll take the sleeping bag liners if nobody else has dibs on them.
Do you want me to come by and pick them up or....
REX
BajaTaco
Swashbuckler
Chris,
REX
Ok, they're yours. You're welcome to pick them up. Just give me a call whenever your ready to come by.
S
Scenic WonderRunner
Guest
Those are some Great offers....Chris!
I think Everyone should be able to own a little bit of BajaTaco History!.....:costumed-smiley-007:victory::sombrero::ylsmoke:
Henrybrowne
