What Welder for a Beginner?
thecriscokid
It's well over due that I get my own welding equipment, but WHAT?
If I can keep it under $500, that would make it happen sooner than later.
I have seen some Lincolns for well under 500, but I obviously don't know much about them.
Any insight is welcome.
Also I'm in Colorado. Just in case someone is looking to get rid of some equipment.
Thanks
dustboy
The first one I bought was a Lincoln 140 HD (the HD stands for Home Depot), and for the price I thought it was a fantastic machine. I think it ran a little more than $500 though. I wouldn't get one of the cheaper Lincolns because they just don't have enough power for the thicker metals in off-road fabrications.
When that got stolen, I got a good deal on a 140 Miller which I bought from a welding shop, it cost a little more but was a slight upgrade due to the "Auto-Set" feature where you set the wire and the metal gauge and zap away. Nifty, and probably a bad idea for a beginner because you would never learn how to set the heat and wire speed.
Between the Miller and the Lincoln, I was actually a little disappointed with the Miller since everybody says they're better. It seemed like the build quality wasn't quite as good as the Lincoln, the handle on the gun has a fair amount of play, and some of the parts seem a little cheaper. Also, when the Lincoln was turned on, the fan made a smooth quiet whir, while the fan on the Miller is a good deal louder. However, I do feel I get better welds with the Miller, which is the point, right?
While we're on the topic, spend a few more bucks and get a self-darkening mask. The old timers will say you don't need it, but it saved me a lot of frustration.
ntsqd
Heretic Car Camper
Can not really go wrong with any of the brand names, go with the brand that you like the features of. Buy a 230 volt machine. Even the largest of the 110 volt machines will come up a little short. They can be made to work, but with needless expended effort. You'll not likely out grow a 230 volt machine any time soon.
Those brand names sold at Home Depot et.al. generally have a lower duty cycle than those same brands sold by welding shops. I didn't realize this until too late. Unless your use is rare, duty cycle will become important to getting the job done in a short time frame.
dustboy
Good point, although I was just about to drop the coin on a bigger 220v machine, then realized you can plug a 110 machine in just about anywhere. Never know when that will be useful.
RHINO
my problem with 110 v welders is that so much of our (4x4 community) projects are in 1/8th" (.120) and 1/4" (.250) material. despite what advertising leads you to believe with true but unrealistic claims of 3/8th" capacity, 1/8th" is about the limit for such a machine to weld comfortably and predictably. 1/4" is doable with solid welds if you know what your doing and knowing when to multi pass ect. but the duty cycle at 20% or less gets old fast.
if you can expand your budget a bit to a 180-200 amp 220v mig machine you will buy once and never need another welder.
in addition to miller and lincoln, Hobart makes a quality product geared and priced more toward the hobby and garage guy.
Antichrist
Can't go wrong with one of these. Make sure it's the AC/DC version, and not the straight AC.
dieselcruiserhead
16 Years on ExPo. Whoa!!
the problem with that machine is its stick. Nothing wrong with that but it takes a different skill set and generally only works well for thicker metals. I use and would strongly recommend a MIG machine if possible, or a small cheaper MIG and then the stick for thicker materials. For a good MIG, I would unfortunately budget closer to $700-$800 out the door for the smallest 210 machine. You can find used machines and they are fine. Millers are the most expensive and I love mine but it was about $1400 out the door. I also had a Lincoln that I liked considerably.
cheers,
Andre
ntsqd
Heretic Car Camper
That was the reasoning behind my buying my 100VAC Lincoln. In retrospect I should have bought the 220VAC machine and done some house wiring. For the heavy stuff I find myself tacking with the MIG and either finishing with the SynchroWave 250 or hauling the project over to a friend's 220VAC machine. That is how I came to drive my FJ60 w/o any front shocks.....
Antichrist
I see that as an advantage rather than a problem.
With stick it's easier to learn to get good welds. Not just welds that look good.
A stick machine will weld 95% of what's on a truck or trailer that you'd be welding.
When you need to weld really thin stuff, for $100 you can set it up to do TIG. Though a stick welder will weld pretty thin material.
thecriscokid
O.K. So it would be wise to start with a 220v, upwards of 200 watt. All very good input. I agree with not worrying with brand names.
Is there much to look out for if I buy used equipment?
spencyg
This Space For Rent
You can find a used Lincoln 175A 220V MIG for under 500. I used to run a Lincoln Weld-Pak 100, 100A 120V and it was a surprisingly versitle machine. Do NOT underestimate the utility of being able to bring the welder to a friends' house and plug it right in. With 220V, there needs to be special electrical accomodations. Yes, my 175A Lincoln does thicker metal, but I got to the point where I could get a good weld in 1/4" steel with the Weld Pack 100 and rarely bounced off the duty cycle. For a first welder, I'd be inclined to suggest a quality 110V machine. Once you get accustomed to it and improve you skills, sell the welder for nearly what you paid for it, and buy something bigger.
Just my $0.02.
Spence
ntsqd
Heretic Car Camper
If you're looking to buy used I would suggest bribing an experienced welder friend to try it out. Run it at both extremes of it's working range and a couple spots in the middle.
R_Lefebvre
I say start with a TIG like I did. ;)
No really, it depends what you want to do, and who you are... MIG is undoubtably easier to do, but I agree with Thom that it's ease results in many cases of absolutely atrocious work being put into service. If you are a perfectionist, and will really dedicate yourself to learning how to weld properly, I think a MIG will serve you well. If you're a hack, and don't do your "best work" until you've had at least 6 beers, I say... don't get a welder.
Stick is going to be cheaper to get set up, but it's harder to learn, and I think most "hacks" can never produce anything usable with it so that probably follow's Thom's line of thinking.
And a bit X2 on the auto-darkening helmet.
spencyg
This Space For Rent
X3 on the helmet. TIG is super fun, but certainly not a skill to be acquired by somebody who has never welded before. Don't get a stick welder...they are crap unless you spend your time welding I-Beams together 75 feet in the air....
logos
I agree. A lot of peole are just putting filler between two pieces of metal. Stick welding forces the welder to actually become good before welding. Plus, they're cheaper.
Also, look for a local community college that offers classes. I just enrolled for the fall semester.
oskarf150
