M416 axle lenght ++++
rugbier
Hi,
does anyone know the axle lenght on the M416 trailer ? ( correct me if I am wrong but I've meassured 57.4" )
I need to know the hub face distance as well as spring center lenght.
And if I could push my luck, does anyone one know a source to get a replacement axle with electric brakes and a bolt pattern of 5 on 6.5
Thanks in advance
rugbier
Nic,
I have a stock axle now , but my goal is to put an axle with 10" electric brakes and Land Rover wheels
The backspacing on LR wheels is 4" with the 5 on 6.5 lug pattern
I've found a local place but no luck with the bolt pattern and they also need the Spring center distance
( My trailer is at the soda blaster, so I can't meassure it )
Thanks
OverlandZJ
Just ran out to the driveway... in the rain. :snorkel:
39" spring distance on center.
Best i can do on width is ~54.5". This M416 is a buds and has wheel spacers and Jeep LJ bolt pattern so the hubs may/may not have been changed.
HTH..
rugbier
HTH..
Thank you
If I see you at RC , I get you a cold one ( for the rain part not for meassuring :coffeedrink: )
