1973 Travel Trailer - "Baby Blue"
dieselcruiserhead
16 Years on ExPo. Whoa!!
Hi guys,
From a couple other posts I received some questions about "baby blue" my wife and I's 1973 Travel Trailer and decided to start this thread.
We bought it last fall as a mental commitment to ourselves to go Burning Man 2009 the following year (which we did, probably for the last time, it was great but it has changed a lot as we have maybe possibly as well), and we also took it on a road trip for our 1 year anniversary down to Boulder/Escalante/Capitol Reef and back and these have been our two road trips. We've also taken it up to Guardsman's Pass locally to camp in an area called Brighton Estates which is incredibly rough roads and it's done great. I bought the 2000 Ford as a new daily driver specifically to tow it (which I know is total overkill but I wanted a diesel tow vehicle versus a V8 or even V6 gas).
I forget the manufacturer but if I remember correctly they are Salt Lake City based. It is a little 10' cube and belonged to an old man who maintained it meticulously. We bought it from his son who bought it from him for hunting but hadn't used it yet and the title was still in the father's name. The son had flipped the axle and added brand new 225 75 R 15 heavy duty trailer tires (which was nice) and discarded the original smaller tires whatever size they were. I only know this because when I re-flipped the axle back to its correct position the new larger tires lightly rubbed in the wheelwells. I moved the axle to below the leaf springs and this was great, provided a 'light lift' that has come in great handy but it still tows solid as a rock to even 80-85 mph which I've had with the Ford and with such a tow vehicle it's solid as a rock of course.
Here are the photos. It has a gas range, a Magic Chef fridge (that at first worked intermittently totally awesome and now generally not too well), and apropane furnace that the thermostat has broken on so it's always on). It was custom wired with 110 in addition to its original 12 volt system. It has a battery but no charger for the battery when in 110 mode. It had a bathroom with a portable toilet but Carrie freaked out about it and made me toss it but looking back I should have kept it if even just to put in the back of the truck. She now uses the space as a closet. The trailer is 10', backs up pretty well, but there is nowhere to sit when the bed is in the down position. We like just leaving it in the down position. We like the trailer enough that I'm considering moving the fridge to the closet position and knocking out that wall to make a bench seat area where the fridge is to add the seating. We really like the small 10' size of it all.
dieselcruiserhead
Here is what she looked like. We paid $800 which we knew was slightly over paying but the interior was immaculate and at the time everything worked perfectly. Also the biggest thing is no leaks ever and it was clearly very well maintained, and we knew it had a lot of potential with a day's worth of paint.
Jacked up and how we bought her:
attachment.php
Lowered when I realized we had larger tires than it originally had. I liked to low rider look but with flex the tires would rub the wheel wells.
attachment.php
dieselcruiserhead
After I flipped it to the right height (you'll see photos towards the end) we started painting. This was one long day with my wife and I and Carrie helped a lot (did most of the taping and painted the inside cabinets).
attachment.php
attachment.php
Typical paint damage on the aluminum exterior where water drips off the windows. This required some sanding but I honestly prepped for maybe 1 hour before painting, it really didn't need much at all...
attachment.php
Starting to spray. I used a cheap 1.4 harbor freight automotive spray gun with about a 1/2 gallon of Home Depot latex designed for a house's exterior (and to adhere to aluminum siding ;) ) the latex was awesome/quick/easy to clean up and very cheap ($15 or so for the gallon retail -- we found ours on a discount shelf for $5!). Were I to spray latex again I'd use a 1.8 tip like what you would use for a bed liner or thicker material to simply spray faster. It took me hours of spraying to get it right with a couple coats...
attachment.php
dieselcruiserhead
Here is the work that Carrie did by simply painting the interior cabinet doors. Worlds of difference and it lightened up the place. It also holds together pretty well even on rough roads. The clock comes down though and goes in a drawer :)
attachment.php
attachment.php
Exterior shots all cleaned up, later that day/evening. She turned out wonderfully and is now probably about a $1500 camper possibly again in a day's work...
attachment.php
Here you can see the ride height which is fairly considerable. We've had no issues with hauling and towing over rough roads...
attachment.php
Titanpat57
You can usually have a bit better success spraying latex by adding Flotrol....it'll thin it down and help it lay out better.
Nice little camper...hell that art deco clock is probably worth $800....you scored bigtime..:wings:
dieselcruiserhead
Here is a neat gizmo I installed in leu of air conditioning. The trailer is actually pretty cool even at really hot temps...
attachment.php
36 year old caulking removal
attachment.php
attachment.php
The new lid installed. Tons of caulk and rubber bushing-ed screws. The loose wires are for a future solar panel some day. I've found some 12 volt 30 amp solar panels with controllers for less than $200 and they should work excellently.
attachment.php
T.Low
Nice find, Andre. I know the story well.
We paid less for this '72 17ft Prowler (everything works, meticulously maintained) than we did for any of our mountain bikes.
dieselcruiserhead
Very cool... I figured I would put up some of the adventures but I think I'll start a seperate thread for that. Very neat.. I was going to say "post up your travel trailers" - they are so awesome.. :)
D
Deleted member 9101
Guest
Man, I lone it.. and it looks great. I have a 1965 Apache eagle pop-up I am redoing.. gotta love those old campers.
Michael Slade
Untitled
If I could find a square-ish short trailer like yours, I'd be seriously tempted to pull the rear box off of the CrewCab and replace it with the trailer.
Very sweet. I like the blue.
dieselcruiserhead
It's nice to see you guys into it, makes my day... It really is a sweet setup. The bed is also.. Awesome :) We put a memory foam and then another 4" below that with a thin board between. The next steps are fix the furnace thermostat and the fridge now unfortunately as well, and then that solar panel and a good stereo and we should be set... It is amazing how little has changed in technology of these over the years except for the super swanky new super expensive ones...
Also one thing I wanted to mention (which is pretty common sense) is the key to towing is proper inflation of the tires at 50-60psi at least and it tows like a dream. 35-40 is nice for rough roads though but you don't notice it either way.
Here is a photo from our anniversary trip. I'm going to start a new thread about it as I mentioned when I get the time... This was night one in Capitol Reef and we were just having a blast. My wife is just awesome...
attachment.php
T.Low
Thanks, I was hoping you'd feel that I was joining in instead of horning in.
Good looking setup, there. Glad to find someone else that understands. When I built the pop top van they told me I should sell the trailer then. Well, I have a free company truck to pull the very inexpensive trailer when we want to base camp, and the van for when we want to off road and thru camp. Makes sense to me.
My mother says I'm pro choice: I believe everyone should have the ability to choose how they want to camp each time.
I've had thoughts of selling the Prowler and replacing it with a modifed tent pop up that will tow easier behind the van...but its hard to part with the Prowler. I guess its always an option.
Other wacky thoughts include getting a pop top from a junkyard and installing it in the Prowler...:ylsmoke:
Happy travels and cozy camp nites, Andre.
bucketosudz
My Grandma and Pa bought the exact series of trailer. Gpa passed about 5 yrs ago and the camper is progressively rotting in the side yard of their home. My Grandma refuses to sell it, as she is certain it will be needed as an extension of her home. Despite my best efforts to persuade her to sell it, she is determined.
They are great little trailers, I helped them bring it home from the PO home.
Yours looks Great Andre!
chet
island Explorer
Cool little trailer. We bought a 12' travelaire in the Spring and used it all summer. No bathroom so it has a bed for my son and the table folds down for us. Mine seems quite heavy for what it is though. Can't complain for $800!
