How to mount and dismout roof mount tent
HMR
Rendezvous Conspiracy
IMO- The whole point of an RTT is EASE OF USE. If the tent is a hassle to mount, I'm less motivated to go camping. With my homebuilt hoist, I'm able to easily install/remove the RTT by myself. If I didn't have the hoist I would've stuck with a quality ground tent.
Fireman78
UUUHHHHhhhh... wife/friend/dad/mom/sbling/kids/neighbor/firefighter/cop/mailman/garbage man.. somebody out there help the dude!
StumpXJ
SE Expedition Society
I put mine on and off several times by myself, but its not easy. Mostly because its too big, not for the weight. Mine weighs about 100 pounds. I just lean it against the side of the jeep, hoist it to the roof rack, then slide it up and on the rest of the way.
I will be building a lift system though soon enough.
~James
Mike S
Sponsor - AutoHomeUSA
We sell the Harken Lift (made in USA) which is inexpensive, designed to do the job, and easy to use. One person can easily remove or remount a tent in minutes.
M
Lemsteraak
Rooftents are pretty large and cumbersome. If you have a lift, you can disregard but if you are going to heft it up by hand, you have to get the weight down. It gets really noisy at the other end if you are lifting more than 50 pounds. Let's say you have a rooftent that is 115 pounds, like mine, take the mattress out. The mattress in my rooftent is 35 pounds so the tent now weighs 80 pounds, piece of cake.
If you are lifting it up by yourself, here is how I used to do it before I put up my lift. I would store the tent on a lift-truck. I have a Columbus so it is quite long and the bottom is totally flat with the mounting system moulded into the base. I would move the tent to the back of the truck, lean it against the hatchback and put a mover's blanket under to protect the paint. Simply lift and push from there. I used to have a big Maggiolina Adventure, one of the really old ones made out of polyester fiberglass, really heavy probably close to 200 pounds. Again, I would do the same thing and it was pretty easy. I would think that this is where the new carbon fiber tents shine, they are really light and if you drop it, so what, probably will hurt the floor though.
Rich H
My problem is that I don't have a garage (apartment), not even a carport that's high enough to drive it under. I also prefer to be able to do it myself. I'm not sure where I can store a gantry crane in my apartment, even with it disassembled!
Stephanie
skysix
Portable Hoist
Autohome Overcamp on a Tahoe. I'm 6'2 and even so it is a bit of a lift as it is narrower than the roof so also have the lousy mechanics of having to reach over the top of the truck. Could strip everything out to lighten but then have to put it somewhere during the process - like the muddy hood....
Makes it a STRONG 2man job, an easy 4 person one (if they can reach that high). Sliding sideways not a great option as bolts stick down from the mounting rails and I've dinged the roof already a couple of ties. Deeply.
Will post pics when done but designing a hoist using recycled 1970's Alaskan camper jacks that can be dismantled and uses the hitch reciever to allow a manual boat trailer winch to lift the tent off the rack, pivot 180 degrees (or more) and set it down on the ground. Allows a semi-permanant setup for when you stay in a spot for more than a few nights exploring locally, and means you don't have to break camp every time you want to wheel.
I have a set of side panels and legs so I can set it up 10" above the ground and have a nice base camp setup...
Errant
Any progress on this?
