Cheaper Scepter Military Style Cans
cruiseroutfit
Are you talking about the red tank in your pic? If so, that isn't the one in the OP's post! That red one may be a Scepter, but it's not the non-CARB version that the OP is talkiing about. My non-CARB one has a screw on vent with a screw on nozzle. The latter has a child proof thing that makes it so hard to unscrew and unloosen that I removed it completely.
The can in my pic is a safety cap version of the Scepter cans, it has both a screw on reversible nozzle (shown out in my picture as the tank was now empty) and a screw on vent. (that was leaking as I mentioned). Given that the nozzle wasn't our problem rather the vent I'm not sure what conclusions your coming to. In addition to that Scepter can I have checked out the exact Scepters's pictured, again, I feel my comments stand.
surfponto
Do any of you Back Country Explores have experience with these cans. If not I will test them out for y'all.
I have a couple of the consumer grade Scepter's as well as a bunch of the Military cans (MFCs).
I prefer the MFC's due to the spout. You can empty 20 Liters of fuel very quickly.
I seem to spill a lot more with the consumer version.
image.axd
peekay
As you probably know, many fuel can companies make two versions, a CARB and non-CARB version. For the CARB version, many use a self-venting nozzle and therefore do not include a separate vent. The Scepter in your picture does not appear (at least in the pic), to have a separate vent. My Scepter has a separate vent that has a bright yellow, screw on cover, just like OP's pic.
I was thinking that perhaps you had the CARB version and that accounts for our different experiences with the product.
skysix
Where did you find the orange Scepters? Also - try removing the 'lead free' baffle/barrier in the filler neck and using Scepters other fill spout. Makes it a LOT faster.
For commercial cans, I built my own filler spout using a 1.25" dia flexible plumbing downspout fitted into a stock spare cap.
DanoWall
