Whynter Portable Fridge/Freezers Now Available @ Sierra Expeditions
flyingwil
Sierra Expeditions is pleased to announce that we are now carrying Whynter Portable Fridge / Freezers.
Whynter Portable Fridge/Freezers offer premium quality and innovative design to your frozen/refrigerated needs. This freezer is great for RVs, boats, campsites, fishing trips and truly portable so you can take your fridge/freezer anywhere! All you need is either a standard household 110 Volt outlet or a 12 Volt power source.
Whether on a day trip or major expedition, you can easily keep your food and beverages chilled, or frozen with this fridge/freezer. The Whynter portable freezers should not to be confused with less effective 12 volt novelty and beverage type "coolers", the Whynter portable freezer fridge is a true freezer/refrigerator which cools between -8°F to 50°F. Using a Panasonic compressor they offer a cost effective and mobile solution for your recreational and critical freezing requirements.
Specifications:
  • Capacity: 45, 65 or 85 Quarts sizes available
  • Operates as a refrigerator or freezer
  • Compressor Cooling System
  • Voltage power AC (110V - 0.7A) or DC (12V - 2.5A Car Lighter Socket)
  • 8' AC power cord and 6' DC power cord are included
  • "Fast Freeze" mode rapidly cools to -8°F
  • Adjustable temperature range: -8°F to 50°F
  • LED temperature display
  • Power low indicator
  • Insulated lid and walls
  • Two removable wire baskets
  • Side handles for easy mobility
  • Floor drain for easy draining
  • Functions even when tilted 30°
  • Tough and solid outer casing
  • ETL approved
  • Warranty: One year labor
Looks a lot like the EdgeStar. Any difference to your knowledge?
(For what it's worth, I love my EdgeStar and totally recommend it to everyone.)
RHINO
i cant tell a difference from the edgestar. and phil,,, do you really have to ask?
Smksignals
the voltage listed above is 12v-2.5 amp. My Edgestar is 24v-2.5a / 12v-4.5a. this fridge looks identical to my Edgestar. Is this really 12 volt 2.5 amp draw? the mfg plate on back would tell for sure.
thanks for checking ...
flyingwil
The EdgeStar is a private label made by Whynter, so this is indeed the same fridge, but with different badging.
flyingwil
Where are they made?
China, and Taiwan
LOL Clay... Seems like everything is coming out of China, if it came from the USA it would be a $2k+ fridge.
Currently Bobby has our test fridge, I will see if he can post up a picture of it for ya!
Here you go, fellas... some pictures that should answer a couple questions that have been brought up, including the one that need-not-be-asked... :smilies27 I haven't had it long enough to conjure up any concrete, original opinions, so I'll let the images do the work for now.
RHINO
far as i can tell it is indeed same as an edgestar, and i have been completely happy with my 45qt edgestar.
flyingwil
Yes they are the same... Whynter produces the EdgeStar for Compactappliance.com / Livingdirect.com; which owns and operates their private label Edgestar products. These fridges are identical in all respects save the private label.
RHINO
well then, they will be/are a great fridge. the only reason these are cheaper is because they havent upgraded and changed the style over the years,, i mean where the other guys are running the latest in plastic bodies and and maybe a bit more efficient system these are basically like the norcolds from a decade ago. i dont have a problem with that.
Hey is that a drain plug in the bottom? Really wish my ARB freezer fridge had that on our last trip out :mad:
The drain plug is amazing. I once had a beer freeze and explode, and another time I had a a tub of salsa overturn and spill... Cleaning? Too easy.
Plus, at the end of each trip, I simply rinse it out with a tub of slightly-bleached hot water, then air dry to prevent any mildew.
This fridge is a winner. Check my build thread for a full review.
off_to
